Question about Bosch HBL5460UC Electric Single Oven
Oven door won't stay closed
I have a bosch hbl546 oven and the door won't stay closed tightly, which allows hot air to leak out while baking. Are the hinges adjustable? Thanks - Mike.
SOURCE: Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Posted on Jan 17, 2008
  • 116 Answers
SOURCE: Oven door not closing correctly
There is some adjustment for the hinges but it involves removing the oven from the wall. On either side (outside) of the oven there is a screw on panel. This panel has screws around the perimeter which can be loosened and shifted somewhat to provide a tight seal.
If there is door is open by any greater than 1/2 inch when it is supposed to be in the closed position then I am afraid that you will have to install new hinge assemblies.
You will have to check your owner's manual to see if you qualify for any warranty repair. The hinges usually cost around $100 each. This link will show you what the hinge assembly looks like:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1094528&PPStack=1
Posted on Aug 06, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Posted on Jan 05, 2009
barkencoa
  • 3463 Answers
SOURCE: Westinghouse oven does not close fully.can door
If it has a drop down door, the only solution is to replace both door hinges, if it is hinged on one side, then the door catch, or door striker could be worn, these are easily replaced,
Please rate my solution.
Thanks.
Posted on Nov 08, 2009
Testimonial: "Thanks for your help.will try that."
barkencoa
  • 3463 Answers
SOURCE: oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Posted on Apr 13, 2010
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
I have a Bosch wall oven in my unit but no user manual. The number on the door is bosch hbe632uau/03. Is it ok to close the door when using grill function or will the glass blow out?
if the grill section is behind the oven door then the door should be open
if there is a door for the grill section then the oven door can stay closed
to get a user manual ,go google and type in-- user manual for bosch oven model ( type in what you have) --( or leave it out if it doesn't recognize the model)
If a page is available with a pdf version you can down load it
Oct 19, 2015 | Bosch Ovens
How do I get a Bosch HBL546 wall oven out of the wall?
if there is trim around it , Iwould remove that first to see if there are any screws.
Jan 11, 2015 | Bosch Ovens
Oven door not staying fully open
phone bosch for clarification first. If this is not the case get the gas board out again
Oct 21, 2009 | Ovens
or
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Nov 21, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Nu-Vu oven will not reach bakeing tempature?
HELLO IM A OVEN TECH AND SEEMS THAT YOU MAY HAVE A FAULTY ELEMENT DEPENDING ON THE MODEL YOU MAY HAVE TWOO ELEMENTS ,ONE IS GONE ,
Jul 10, 2008 | Nu-Vu NUV-MDO11 Stackable Deck Oven 1...
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch HBL5460UC Electric Single Oven Logo
173 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
