Question about Dell Inspiron 6000 Notebook
My laptop will not start up.
When unconnected to the computer but plugged into the mains, the green light on my adapter shows it is on but as soon as i plug it in, the green light fades away and nothing happens to my computer. It hasnt been switched on since mid august.
  • MzAnny Nov 21, 2008
    The same at Potdog1, only my laptop was in regular use. I went to log back in after a nights standby and the power was completely out. I thought perhaps the power cord had come loose. So I reconnected, tried again and found that the light indicator on the power cord died after plugging it in. I repeated this several times, took out the battery tried it again and still had nothing. I bought a replacement battery from Dell hoping (REALLY hoping) that was my problem. But it wasn't.
    I read your post, that the motherboard is most likely the culprit. My question is since the Inspiron 6000 is several generations old now, how expensive is the replacement and how likely is it that the part is available new.
    Thank you
    Ann
  • 59 Answers
There is a short on the motherboard. sad to say but the only way we can fix this is through a motherboard replacement. it is dell SOP to replace mobo for this issue. if the warranty is still active you can call us at 800-8228965. if its out of warranty you can call  800-2884410
Posted on Oct 19, 2007
Sir i have acer 4720Z series laptop. when I plug in the power adapter it show adapter light green. when adapter pin connect the laptop then light show blink and laptop not charging.
Your laptop battery seems to be broken.
To be a 100% sure, can the computer run on only battery?
Try to have the computer plugged in to the charger for a couple of hours without starting it.
Feb 28, 2011 | Acer Aspire 4720 Notebook
My computer won't turn on at all, the green light comes on but only a black screen shows. When it was plugged in to power the light wasn't showing that it was charging so took out the battery and then...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Dell D610: Does not charge w/ any a-c adapter/battery pack.
This seems to be a shot in the charging circuit of the motherboard. If in warranty call Dell hardware supoprt and they will do the needful in warranty. If the warranty is out try a local technician and maybe they can repair the board.
Aug 10, 2009 | Dell Latitude D610 Notebook
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
Mains switch on
some shortage inside the computer, go for technical assistace from qualified technician
Nov 04, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 6000 Notebook Logo
Alun Cox
