Question about Zebra Printer 140-751-00000
Changing from labels with black bar to ones without.
I'm using a Zebra QL 220 plus printer. Can the printers be set up to sense the gap?
  • 355 Answers
Actually can you be more specific about detail???
Depends on what software you are using, but you can use any True TypeFont for the human readable, and any propritry barcode font availableas downlaods.
However these barcode fonts tend not to print very small, it is a matter of trial and error.
www.lancerlabels.co.uk
Posted on May 19, 2009
I changed the Label Roll in my Zebra QL 220 Plus. After I turn on the printer it prints labels continuously and on the screen it shows "Extended Two Key". How do I get rid of this problem?
Extended two key means one of the buttons by the LCD are sticking and not releasing, you use the two key sequence to print a device configuration but if you hold in the buttons for too long r they are sticking that's when you get the extended two key error.
Nov 18, 2014 | Zebra QL 220 Plus Label Printer
Media cannot be recognized after switching to GAP-SENSE
Try referring this issue directly to Zebra for resolution.
Mar 03, 2014 | Zebra QL 420 Plus Thermal Label Printer
How do I change the Top Of form setting
jscholten695: You have doing it in your label design software, inside printer you cant adjust this offset.
Aug 26, 2011 | Zebra QL 220 Plus Thermal Label Printer
Hello i have had problems with QL220 plus printers that feed 7 more empty labels after printing one label. I cleaned the sensors and reloaded the firmware and it's still the same. is there any fix...
akos_brachna: You must have change the label sensor value, if using the Label Vista software, you can do this. But you must have made in software, not in printer.
Jul 28, 2011 | Zebra QL 220 Thermal Label Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
My printer won't caliberate using a 1.25 inch circular label. The label stock is white, the backing is an opaque whiteish with black lines between each...HELPPPPP
Zebra printers use 2 methods to sense the gap between labels. Transmissive or Reflective. Your labels have a black mark on the backing. Your printer uses these black marks to detect the gap between your labels. Ensure that your printer's mode is set to REFLECTIVE & check that your printer driver media also is set to BLACK MARK. Print a config label to look at your printer settings.
Nov 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra QL 420+ wireless printer works only without cipher/TKIP
Hi
With Label Vista
  • Go to Printer Tab
  • Define the com Port settings (use serial or usb)
  • Go to Printer settings
in network tab :
  • Put your network configuration ( IP address or DHCP,submask, gateway; ESSID, port number .....)
In 802.1X WPA
  • Select WPA WPA2
  • Authentification PSK
  • Put the username and password in EAP section
Mar 16, 2009 | Zebra QL 420 Plus Thermal Label Printer
Zebra Printer 140-751-00000 Logo
150 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
