Question about RTO Mini Quads
Apache 50cc quad bike keeps cutting out. No problem starting it but It cuts out
3 Suggested Answers
SOURCE: hi have a yiying 50cc moped and it keeps cutting out and its slow
take it for a full service, clean it, check your brakes r not to tight, check all your oil levels, clean your ait filter ( all done in ur service), check your bettery isnt flat, all that kind of **** n hopefully it will be a smooth runner again
Posted on May 07, 2010
SOURCE: Hi, My sons Apache quad bike has no spark I have
hi my quad wont spark can you help ?
Posted on Jul 07, 2010
Hi, anyone know what the factory carb settings are for an aeon mini kolt 50cc. Having problems with getting it started, changed spark plug and battery
Two-Stroke Scooter / ATV Carburetor Settings And ...
? 4:37
https://www.youtube.com/watch?v=A1vRMERs4RQ
Jun 2, 2012 - Uploaded by 90GTVert
Part 2 of a 4 part video detailing all of the basic settings and ... Two-Stroke Scooter / ATV Carburetor Settings ...
Fix your Mini bike Carb - bogging, cutting out etc - YouTube
? 4:51
https://www.youtube.com/watch?v=lbtDMFUiD0k
Aug 15, 2011 - Uploaded by Cpt MishMash VonRandom
If you are having trouble with your mini bike/quad whereby its difficult to ... Two-Stroke Scooter / ATV ...
quad 50cc carb Questions & Answers - Fixya
www.fixya.com > Forum > Tags
50cc carb wondering what the factory setting is for a 2002 50cc Kawasaki kid's ...aeon mini kolt 50cc quad will rev a little then cuts out no power Likely a lean ...
Aeon mini kolt 50cc quad will rev a little then cuts out no ...
Jan 05, 2016 | Factory Motorcycles
TVS Apache RTR 160 - Engine Valve Cut.
200 rs for each valve (oe), 300 rs service charge...
Apr 01, 2014 | 2010 TVS Apache 150
My apache 50cc quad has a new carburator but it's keeps flooding and cutting out
1. fuel pump to strong.
2. needle seat blocked.
3. wrong carb jetting
this is possible faults
Mar 23, 2014 | Garden
Apache quad
carb might be clogged clean it
Mar 21, 2014 | ATVs
My apache rlx 450 sport Quad bike keeps cutting out when at stand still.
i have the same quad with the same problem,its done every experts head in,take the seat off and look down the left hand side of the inlet manifold there should be a small peice of rubber hose about an inch or so,check to see if it has a screw in it or a plug if not put a screw in it,it will then rev higher just turn the rev screw on the right of the carb outwards untill tick over is about 1700rpm
Jul 09, 2010 | Cycling
Got a kazuma 50cc quad have problem starting it when i finally get it going it wont take any throttle without cutting out.
i have i 50cc ATV quad and we have done every think to it and it still won't start but the fuel isn't going to the spark plug any one know what to do. ?
Jan 09, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Wiring diagram for 50cc koala quad please quad not starting no spark several wires disconnected including safety cut out at rear, can't see where rest of circuit wires are.
A service manual is a valuable tool with an aging bike. I suggest the dealer/mfr. or Clymer books. In the meantime, go to the library reference section...646 stacks should have what you need.
Sep 28, 2009 | 2003 ATK 600 Dirt Track Motard
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There may be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
May 17, 2009 | 2004 Factory bike Chrono SM 250
RTO Mini Quads Logo
20 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
