How to connect my crate gt65 to a pa mixer - Audio Players & Recorders
  • 35 Answers
The best way to get the sound you want coming out of the pa is to mic up your cab. That way you can perfect the sound you want in the cab using its own controls, plus any outboard gear you are using. Position the mic half way between the centre of the cone and the outer edge of the speaker. You have to try different mics to see what you prefer but you could start off with a Shure SM57 and you'd be sound!
Posted on Jan 08, 2014
I have a CRATE PA-6350 Need a user manual to adjust the settings
Try Googling (CRATE)(PA-6350)(manual) without parens.
May 30, 2017 | Car Audio & Video
Crate gtx212 mute circuit (Q24 across IC4A pins 1 and 2) should go positive on the gate when a plug is inserted.
Looks like Q24 changes the gain at IC4-A from low with no input jack to normal gain with a jack inserted. Since this appears to be a guitar amp that expects a floating input plug any connection at the input to say, a mixer etc may cause a re-grounding via that equipment's circuits, thus negating the auto mute...... eggs & suck :-) If using a moving coil meter it could upset things.... an interesting fault! Sorry I can't be more help - Good luck!
Feb 11, 2017 | Crate Music
Mixer to P.A. system connection
You'll want to use the Stereo Out connections at the top right. You might need adapters to plug into whatever system you're trying to use. Also note that this mixer does not provide power, so the speakers you're using have to be self-powered or be driven by a separate amplifier. You would then plug the Stereo Out connections into the INPUTs of the amplifier.
Jun 28, 2013 | Nady Systems Nady SRM-10X 10-Input Mixer
Connect a mic mixer to a powered mixer
What kind of output does the mini mixer have? If may not have enough to input your Carlsbro PA
Nov 16, 2011 | Radio Communications
What do I need to hook up to our church pa system
Connection all depends on what type PA system you have. Here are the rules: Power this device from the SAME receptacle your mixer is powered by, even if it means running an extension cord. Use ONLY a balanced line from the mixer... either TRS cable or XLR cable.
Apr 02, 2011 | Samson Auro D412A Speaker PA Active
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How can I make this sound great.
line out from mixer------to crossover in---------crossover out-------to amplifier line in-----------from amplifier out--------to loud speaker.
---from low output(low frequency)of crossover-----to line in in subwoofer.(mixer is ordinary mixer not powered mixer- and in case of powered mixer take care it is line out(0db---to4db)not amplifier out which you connect it to loudspeakers.
May 19, 2008 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
63 people viewed this question
 Grubhead
Grubhead
