Question about MTD PRODUCTS INC 28 .in 2Stage Snow Thrower 31AH65LG704
Starter motor turns over but does not engage with the motor
  • MTD PRODUCTS... Master
  • 2,478 Answers
Check voltage at starter when key trying to start.
Posted on Dec 31, 2013
Testimonial: "The starter is 1 you plug in to a 110 outlet ."
Starter motor wont engage ?
Check by getting a screwdriver and bridging the terminals on starter if it doesn't turn try couole o wacks I know sounds funny but does actualy engage the pin
Mar 06, 2015 | Ford Cars & Trucks
Starter not turning over engine
Does it engage and keep turning or does it engage and stop? This is critical to what is causing the problem. However regardless of what is causing the problem, the starter motor is going to have to be removed. It could be that the gear splines are not aligned properly, so that the starter gear is not fully engaging.
Feb 27, 2015 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
I have a 2000 toyota celica gts and it wont start or turn over the starter will make like a whinning sound but its not trying to crank the engine maybe its the starter but just in case its not anybody have...
Likely either the starter or solenoid. Solenoid is a combination of relay and actuator, pushing the starter's gear into engagement with your flywheel.
Oct 28, 2014 | Cars & Trucks
My truck motor wont turn over? The started is kicking in ' but the motor does not turn to start?
You say your starter is kicking in..is it spinning and not turning the engine over? If so you have a problem with the flywheel teeth or starter gears not engaging..if no spin just a click..your battery is to weak to turn engine or you starter selonoid or starter needs replaced...good luck..
Mar 05, 2014 | Betty Boop Leg Kicked Up Wall Laptop Car...
My van will not turn over,i thought it was the starter cause it wasnt starting it will turn over but not start.so i put a new battery in it cause i was told the old one wasnt kicking out enough amps.and it...
If the starter motor spins and does not engage, thump the case of the starter motor with a piece of 4 x 2 or a lump hammer handle. If that fixes it, the fix will be temporary. Take the motor off and lubricate the bearings, paying attention to the dog wheel slider.
Oct 01, 2017 | 1992 GMC Safari
Solenoid clicks will not engage 4000KW Onan
4000 kW is a very big generator. I asume that your is 4000W = 4 kW.
If - with electrical start it should be MicroQuiet 4000.
Never mind by all types of electricaly started engines this will mean:
If by "not engage" you mean that solenoid only clicks, but neither the starter motor is turning, nor the bendix wheel is engaged to wlywheel. This may mean that battery voltage is low, in order to engage the bendix and make its power contact, or the bendix is mechanicaly blocked.
If by "not engage" you mean that solenoid clicks, the starter motor is not turning, but the bendix wheel is engaged to wlywheel. This may mean that the bendix relay power contacts are bad or starter motor collector or brushes are bad.
If by "not engage" you mean that solenoid clicks, the starter motor is turning with a scratching sound, the bendix wheel is partially or not engaged to wlywheel. This may mean that the bendix throw out lever is bent or broken, or the wheels on bendix and flywheel are worn out..
Aug 01, 2010 | Watts Onan Portable Generator - 4000 ,...
The motor turns but will not start. It appears
. you lost me ! motor turns . that would make one think the starter is engaging. not firing might be ignition problem.
May 01, 2010 | Boating
Starter not always turning motor
Possible solution. You probably know that harleys, unlike almost all the others used a bendix type to shove the starter motor's gears into engagement with the starter clutch. Since you replace the solenoid, the thing that pushes the gears into engagement; the battery, that would push the starter motor if the gears were in engaagement; and the starter motor, which would turn the ring gear if it was in engagement. So wht's left? Unfortunately it sound like it might be the teeth on either the ring gear or the bendix gear, probably the ring gear as it was notoriously weak on iron sportys. Not a problem you want to try to fix at home unless blessed with tools, room and time.
Apr 07, 2009 | Harley Davidson XLH 1000 Sportster...
MTD PRODUCTS INC 28 .in 2Stage Snow Thrower 31AH65LG704 Logo
112 people viewed this question
Top MTD PRODUCTS INC Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a MTD PRODUCTS INC Garden Expert? Answer questions, earn points and help others
