Question about Bosch HGS232UC Gas Kitchen Range
Error 43 keeps Flashing and Oven Turns Off
When I use the oven, it can either suddenly turn off and start a continuous beeping with Error 43 flashing or, after I'm finished using the oven, it will start the above. I'm afraid to use the oven and it doesn't happen all the time. The only way to "fix" is to unplug the stove until it completely 'cools' and then plug it in again, making sure to open the oven door at the same time since it locks the oven door when the beeping comes on. HELP.
SOURCE: Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Posted on Jun 17, 2008
  • 161 Answers
SOURCE: GE profile glass stove top
You got one or more of the burner switches wet. (It usually happens when you wash the knobs and water stays in the holes until you replace it on the shaft) If just water they may work after a day or two. try using a hair dryer, Keep it at least 12 inches away. If oven cleaner or other chemical got inside switches they may need to be replaced. If you can't dry them out. Disconnect the wires from all but one switch at a time and see which one/s need to be replaced. Sometimes the electric part of the switch can be seperated from the gas part and replaced seperately. DO NOT LEAVE THE STOVE PLUGGED IN until you fix this problem. There have been reports of fires started from this electrical problem. You could also burn out the spark ignightor. The fire problems have been mostly with Maytag/Jenn air products but my whirlpool blew a fuse and shot sparks when this happened to me. I just replacet the whole cooktop as my gas valves were one piece units and way to expensive to repair.
Posted on Jun 29, 2008
SOURCE: i have a bosch exact
Well i now have the answer to the bosch stove dilemmas if you have a glass touch panel on your bosch stove and you can't get the touch buttons to work right then check the circut board on the back of the glass it is cheaply held to the glass with a non hardening caulk and when your oven heats up the glass panel
the caulk gets so soft that the circut board and the caulk seperate causing inconsistent button operation. To solve this push the circut board and its frame back to the glass then get some aluminium tape at the building supply you shop at in the heating section and tape it into place so it can't seperate anymore then it should work for you. Make sure you have everything grounded properly.If you are concerned about the grounding you can use duct tape to be safe. ( there has been a lot of complaints about glass touch panel incosistentcies on more than one model so im 90% sure this will fix those too).
Posted on Aug 06, 2008
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
  • 833 Answers
SOURCE: how to remove smoke stain ?
Try a mild abrasive cleanser like Bon Ami or Soft Scrub and wipe clean.
Posted on Nov 12, 2008
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
Oven turns on by itself and F1 flashes on the digital clock
Without being able to look up the error codes for your model (number please!), I would guess that the oven control triac has shorted out or the relay is stuck on (I assume the oven runs at maximum temperature). In any case, the oven microcontroller knows something is wrong, so it says F1 and beeps for help.
Aug 10, 2009 | Kenmore Kitchen Ranges
OVEN SHUTTING OFF, CLOCK FLASHING
ve continually had the same problem for years. Now the display flashes F1 and beeps continually and I have to keep the unit unplugged. I can use the burners and manually light them but the oven is unavailable because there's no power.
Mar 29, 2009 | Tappan TGF657 Gas Kitchen Range
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
F2 error
what is solution
Dec 08, 2007 | Ovens
Error flashing F5
We had a similar problem where F5 was flashing but the burners actually continued to work. It turns out that this was related to moisture (the problem typically happened when boiling water). Adding a strip of aluminum tape inside the back panel seems to have solved the problem (fingers crossed).
Oct 11, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 | Ovens
Message panel keeps flashing F10 error
Code F-10 indicates a temperature runaway. There are two possible problems. 1) The oven temp sensor has failed. This can be checked using a standard multimeter. The sensor is located behind the rear access panel of your oven. The sensor should read about 1100 ohms at room temperature. 2) The oven control board needs to be replaced. There are no FRU's (field replaceable units) on the control board. Check the sensor first. Even a new control board is cheaper than a new oven.
Deepwater
Apr 19, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Bosch HGS232UC Gas Kitchen Range Logo
107 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
