Sc 46-91 konica minolta 7255
Nitrotrike
  • 589 Answers
SOURCE: Konica 7255 diaplays a F56-04 code when IP is installed
That is correct. The IP511A is for the 7255 / 7272, and the IP511 is for the 7155 / 7165.
This is probably due to these machines using different image processing boards.
I am actually surprised it lets you get as far as you did with it.
Posted on Feb 08, 2008
firecontrol7
  • 6161 Answers
SOURCE: Error SC 29-03
Max Density error. Clean the senor looking at the drum?
Posted on May 09, 2009
cirocpatel
  • 524 Answers
SOURCE: SC 53-01 Service Error
1. Outdated firmware.
A flash ROM upgrade is available to correct this problem.
Notes:
a. See bulletin 3481A for details on this issue.
b. Make sure that the current version of system software (with applicable patches) is installed on the controller.
2. Improper shut down procedure of the controller.
Here is the correct shutdown procedure:
a. Shutdown the controller via the Di551 control panel.
b. Turn off the sub switch (front switch) of the printer.
c. Turn off the main switch (rear switch) of the printer.
This procedure assures that the controller and printer are properly synchronized when power is applied. If the sub switch (front switch) is the only switch
turned off, the Service Code will be generated the next time the printer is restarted.
Posted on Apr 29, 2010
  • 10 Answers
SOURCE: Hi, We have a Konica-Minolta 7255
Are you using the same software program when you print? If so, go into the software, printing options. Often, there are printing options that you can set up just by clicking a little box that will turn off the cover page feature.
Posted on Sep 02, 2010
SOURCE: konica minolta bizhub 920 error code sc 46-16 pl
konica minolta biz hub 920 error code sc 52-09
Posted on Feb 28, 2011
Sir MRE Konica 7255 mn likha ah RHA hy report code sc90-01 plz helpe ks tara thek ho ge
Automatic duplex drive (What allows double side copies) motor or board. check the motor in 47 mode,
Dec 25, 2016 | Konica Minolta 7255 Lower Fuser Picker...
Konica minolta 7255 error code sc 28-02
Below the drum is a assy. which has two/three very fine wires each carries a High Voltage (Only) during the copy process. the paper goes between these wires and the drum. The wires allow the paper to steal the image off the drum. Well these wire can become dirty, so they have a motor that runs a small cleaning pad across them, your code deals with that open the center section should see the assy. might be the one of the cleaning pads is stuck, the pads work go from one side (Rear to front/front to rear) to the other and back job done. Is the pad in the middle or stuck.
Remove the assy. and bring the pad to the front. Also can allow the motor not to do anything. In service mode 25.
Mar 17, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta 7255 error code sc 77-02
http://www.fixya.com/support/t12138228-konica_minolta_7255_error_code_sc_77_02
Feb 11, 2015 | Konica Minolta bizhub Office Equipment &...
Konica minolta 7255
Sir/Mam,
Something went wrong with the machines image control board. Check all connectors reseat each and very one pull each out separately and check for a bent pin. Time consuming but the board could cost $1000.00? give or take if you can find one.
May 23, 2014 | Konica Minolta 7255 Lower Fuser Picker...
CODE 02-01 SC23-04
Sir/Mam, please check the model and the code looking at service manual for the Konica Series 7255 not such code per what model you currently have this problem with
Feb 08, 2013 | Konica Minolta TN601K Toner for 7155,...
CODE 02-01 SC23-04
PCL connection area. Mite want to check all connections to the print control board. And Memory sticks, also have the firmware re-flashed.
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
62 people viewed this question
jasbo
jasbo
