Question about TP-LINK TL-WR740N 150Mbps Wireless Lite N Router IEEE 802.11n IEEE 802.11g IEEE 802.11b Built-in 4-p... (813120016543)
Fix directv dvr
Router settings ploblem
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV Genie® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your Genie® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
How do i reset my dvr
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:-
CCTV Networking Technical Support
Jan 13, 2016 | Swann Communications Home Security
Have a DIRECTV mobile internet stick, which plugs into a USB port to have internet access. I want to make my internet access a wifi access. What do I need to do this ?
If you do not already have a wifi router you will need to purchase one, install it and connect your Directv receiver to it. If you do have already, you will have to go through the settings on your Directv receiver to setup a wireless connection.
How to connect your DIRECTV Plus HD DVR to your home Wi Fi network with...
Jul 30, 2013 | Linksys Wireless-G WRT54G Router
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
Trying to connect to directv dvr for ON Demand services via ethernet cable, but directv dvr doesn't recognize connection
Run your DVRs outomated network setup.. If this fails, you will have to get the ip settings manually. to find them, use a computer that is connected to the router.. Do start, run, type cmd, press enter. In the black window that comes up type ipconfig /all this will give you the settings the DVR wants. choose manual setup from your DVRs network connection menu.
Sep 29, 2010 | 2wire (1000-400108-001) Router
How to configure 2 Linksys router and connect to Direct TV DVR on demand?
No configuration is necessary. Simply run a RG45 cable between the router and the DirecTV box. DirecTV will begin communicating immediately with the internet.
Oct 09, 2009 | Linksys WRT160N Wireless Router
RCA DVR-40 Directv receiver will not make a call to Directv
i believe you have to slow the modem speed down. contact directv 800-531-5000 on instructions how to slow the modem speed. tell them you are getting "service not answering" hope this helps!
Mar 22, 2009 | RCA DVR-40 DirecTV DTV Receiver / 35-Hours...
Connecting my router to my Directv DVR
If you are using an AT&T supplied 2-Wire router - then I have the same setup.
It does work.
First you can check to see if DHCP is doing the job.
Go to your router address:
(something like 192.168.1.254:5000) < they should have given you this on install)
Look at your network and see if the DVR is there.
If so, note the address.
Now go to setup on DVR and see if it has the same address.
If not...
You don't need to change the router to static, but it helps to change the DirecTV dvr to static.
I have the HR-20.
Give an address in the range of those leased by the router.
192.168.2.166 or something.
Make sure your first 3 octects match your router ie: 192.16.1
Just go to setup on the DVR and change it to the hard IP address.
If the router is not uPnP (2-Wire is not), then you may have to open a port or tow to get DirecTV VOD to work (maybe not or I don't remember which ones, googe it.)
The IP Mask should be 255.255.255.0.
Open the screen with the button below the lower DIrection Switch.
It is the you go for
'Find SHows'
"manage Recordings"
If you see a new entry entitled "Pictures, Vedeos and more" then you are online.
If not --- google some more.
Oct 13, 2008 | 2wire (1000-400108-001) Router
Hi
Have questions about your upgrade? We've got the answers. What do I need to do to receive my upgrade? Nothing! Just make sure your DIRECTV HD DVR is continuously connected to your land-based phone line and you will receive the upgrade automatically. When will I receive my upgrade? The 6.3 software upgrade will roll out over a period of several weeks. Customers with more than one DIRECTV HD DVR may receive their upgrades at different times for each receiver. We appreciate your patience while we deliver these new and improved features to eligible DIRECTV HD DVR customers nationwide. Are all DIRECTV DVRs receiving this upgrade? No. DIRECTV DVR models SONY SAT-T60, PHILIPS DSR6000R and HUGHES GXCEBOT will not receive the 6.3 software upgrade. Other models received a similar upgrade, 6.2, in the past. I have a DIRECTV R10 DVR with 6.1 software. Will I receive this upgrade? No. The 6.1 software on the DIRECTV R10 DVR already includes the 6.2 features such as folders and faster menu scrolling. Will any of my DVR settings be changed as a result of the upgrade? Yes, some of your settings or preferences will be changed back to the factory default settings as a result of the upgrade. These include: "Favorite Channels," "Channels You Receive," "Spending Limits," "Clear Channel Banner Quickly" and "Dolby Digital" recording and output. To change Channel Banners, Channels You Receive and Favorite Channels preferences: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Channels" To change Spending Limits: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Parental Control" To change Dolby Digital Settings: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Audio" 4. Select "Dolby Digital" and "Digital Output" Will I be charged for this upgrade? No. We're upgrading your DIRECTV HD DVR as part of your normal DIRECTV® DVR with TiVo® service at no additional cost. What happens if I don't have my phone line plugged into my DIRECTV DVR? You will not be able to receive the upgrade if your DIRECTV DVR is not connected to your phone line. To install the upgrade, your receiver must successfully make a call to our servers. How will I know when I have received my upgrade? You'll receive an on-screen message the first time you visit DIRECTV Central after your upgrade is complete. It will also appear in your Messages section. You can also check your System Information screen to find out which software version you currently have. Will the download delete any of my currently saved programs? No. All of your saved programs will still be there for your enjoyment after the installation. Once your upgrade is complete... How do I activate the Grouping (folders) option? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change groups to ON. SHORTCUT HINT: While viewing your Now Playing List, press number 2 on your remote control and your Now Playing List will change from the GROUPS view to show each individual recording. Press 2 again and it will switch back to the GROUPS option. How do I sort alphabetically instead of by date recorded? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change sorting option to Alphabetical. SHORTCUT HINT: While viewing your Now Playing List, press number 1 on your remote control and your Now Playing List will change from alphabetical to date sort. Press 1 again and it will switch back to alphabetical sort. Some settings will restore to factory defaults when the new software is download
Aug 19, 2007 | RCA DRD485RG DirecTV DTV Receiver
Open Questions:
See all TP-LINK TL-WR740N 150Mbps Wireless Lite N Router Questions
TP-LINK TL-WR740N 150Mbps Wireless Lite N Router IEEE 802.11n IEEE 802.11g IEEE 802.11b Built-in 4-p... (813120016543) Logo
29 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
