Question about Maxim Railway Express Battery Powered Engine Fits Wooden Thomas Train
Gears for brio engine
I opened the bottom of the engine thinking the battery was there. It wasn't, of course, and the 3 gears fell out. Can you please send a drawing of the order the gears go in? Thanks much. John at pastorchadwick2hotmail.com
What is the price of a crached hyundai brio 2008?
This depends on many factors. Is there damage to the chassis or engine? How many miles are on the car?
Jun 29, 2017 | Hyundai Cars & Trucks
Cannot put insides of Brio battery driven toy engine back in the right way
Perhaps this picture will help you to place the cogs in the right way... cannot-put-insides-brio-battery-driven-kq1qrvxr24imymdlun3n2qdr-3-0.jpg
Mar 30, 2013 | Brio Mighty Red Locomotive
My Brio RC train Express model, does not work, changed batteries,tried both channels A@B, and cannot find solution, please help
Hi, Im actually looking for instructions for this train online? cant find any?
But.... I think your problem may be down to the fact that the train itself has 2 separate battery compartments! one in the front carriage holding 2 x aa batteries [which powers the wheels and headlamp] and one in the rear carriage which holds 4 x LR44 button cells [to power the rc link and sound effects] not obvious.
What I want to know is what are the little black and red buttons for?
Feb 05, 2010 | Brio Toys
Brio remote control express doesn't move anymore
I wish I could help - I have exactly the same problem! Train opened Christmas Day, worked ok. Batteries seemed to gradually die 2-3 days later. Replaced all 3 sets of batteries twice, but nothing. Initially I got sounds, but nothing now.
Dec 27, 2009 | Brio Remote Control Express Train
How do i change a battery?
Look for a tiny cross head screw then look for a small cross head screwdriver! ;-)
That will open a compartment that you need to put 2 AA batteries in.
Don't open the triangular screws - you will have tiny cog wheels all over the floor!
Dec 23, 2009 | Brio Polar Express Battery Engine
How to change the battery in train 512
Hi Tarja, your question is 4 years old, but here is the answer:
You've probably seen the odd shaped tiny screws on the underside of the train. Ignore them - they require specialized tools and only lead to the wheels and gears.
You just need to insert a small cross-tip screwdriver into the exhaust funnel of the engine and remove the screw completely. The black front of the engine comes off and reveals AAA micro batteries which you gently shake out of the engine and replace.
As ever so often - once you know how to do it, it is very easy.
And - no, I didn't find out myself either *grin*
Nov 08, 2009 | Brio Mighty Red Locomotive
My granddaughter has about a dozen Brio batter-powered locomotives. Three of them will not move, even with new batteries. Two of them still light their lights and make train-whistle sounds. But they won't...
Alas, the traction drive on these Brio locomotives seems to have a pretty short life. According to a Brio rep, the only hope is to indeed give it a good firm solid whack down onto a hard surface (table or floor) in an attempt to get the internal pressure gears to settle down and get more traction. There's a 50/50 chance it might work. There is no other solution. Attempting to open it up will create a mess because it's almost impossible to get all the tiny loaded springs back into place. At least the lights and sounds still work, and it can be easily pushed around the track--it just will no longer do so itself...
Mar 06, 2009 | Brio Mighty Red Locomotive
Need to replace battery in brio big red engine
There is a battery down deep in the steam spout on top (black chimney type thing). Unscrew it and it slides off the front and allows you to insert 2 AAA batteries.
Dec 08, 2008 | Brio Polar Express Battery Engine
Problem in 1st gear with manual transmission
Ignition timing may be too advanced or ******
Check ignition timing first.
Check for rated idle speed
Check engine compression pressure
Oct 28, 2008 | 1996 Toyota Corolla
Maxim Railway Express Battery Powered Engine Fits Wooden Thomas Train Logo
123 people viewed this question
Top Maxim Toys Experts
ray gallant
Are you a Maxim Toy Expert? Answer questions, earn points and help others
