Question about Toshiba Satellite A215-S7422 Notebook
Laptop Toshiba connected to a Epson projector. It freezes when I play a DVD
Hello, I connect a Toshiba Laptop to a Epson projector and everything is all right until I want to see a dvd. When I click on play the computer freezes. Thanks
Laptop vs. Projector
I would guess, remove Win8 and go back to a proper OS.
Mar 20, 2014 | Mitsubishi XD206 DLP Projector
Epson projector
check HDMI port, whether it is work well.by connecting another laptop.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Mar 01, 2014 | Office Equipment & Supplies
Hello i have a problem i have a epson ex30 projector and i cant make it work with mt toshiba labtop
Hello:
When connecting a projector or second display to your laptop, you may need to tell the laptop to "clone" or "duplicate" your display onto the second device. This can be done one of two ways:
  1. A key combination on your keyboard.
    A. While holding the Function or Fn button on your keyboard, press the
    Function key that shows a picture of a monitor or a computer and a
    monitor. On my Toshiba laptop, this is F5.
    B. You may have to press the Function key multiple times. If this doesn't
    work, proceed to option 2.
  2. The video card driver's settings.
    A. Navigate to Start>Control Panel>Display
    B. In Windows 7: On the left-hand side of the window, choose "Connect to a
    projector". A dialog box will popup. Choose "Duplicate".
Mar 06, 2011 | Computers & Internet
I want to play a dvd on my slide projector is this possible
yes
You need to connect you dvd player to the projector with video leads.
(hdmi, svideo or component) depending what your dvd player has.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Epson EMP-S1H Multimedia Projector
Cant get it to work with laptop
power ON your projector and laptop
connect your laptop and projector with VGA cable and press
if your laptop PANASONIC or NEC (Fn+F3)
ACER, HP,SHARP,TOSHIBA (Fn+F5)
LENOVO, SONY (Fn+F7)
DELL, EPSON (Fn+F8)
FUJITSU (Fn+F10)
APPLE (F7)
If problem exist remove the VGA driver in your laptop and reinstall the correct driver not a standard display driver
Feb 09, 2011 | Panasonic PT L720U Multimedia Projector
Can't project video from laptop connected to NEC NP100
you can plug in to a laptop if the laptop has vga out. affter plug play the film or something and give the view to projector. need to pushing special button on keyboard. which is with FN
May 30, 2009 | NEC NP100 Projector
Help
The projector probably has a user manual, right? Have you followed the steps in connecting pc with projector? You might have missed a setting or something and need to re-check it.
May 30, 2008 | Toshiba Satellite L20-S310TD Notebook
DVD playback through vga out
hello..!
You have, to On your laptop first, before you connect your projector,then change your display settings to (color quality to 32bit)after you change, connect now your projector,then press and hold the fn functions key while pressing the Fn key ,you press the F6 or any of the funcion key with the display of monitor
once. just repeat until you get the right keys.
p
Mar 29, 2008 | Compaq Evo N610C Notebook
Epson Powerlite 1815p screen projector - DVD playback video jerkiness when there is motion in the video
I am assuming that the DVD plays normally on the display of the Dell 745.
Then the issue(s) may be with the:
1. Networking configuration/set-up of the Dell and/or the Epson;
2. ethernet cable;
3. configuration/set-up of the projector or the Epson itself.
A couple of things you can try:
1. Optimize your networking throughput.
1.1 Increase your PCI Latency Timer to 128 or 255 in the Dell's BIOS/CMOS setup (if present);
1.2 Try running DRTCP.exe and/or TCPOptimizer.exe appropriate to the Dell's OS;
1.3 Disable all other networking activities on the Dell. This may include auto updates, security/antivirus checks, etc. while running the DVD;
1.4 Slim down Dell's startup programs to bare minimum;
1.5 Increase your OS' swap file to roughly double your onboard memory
2. Try running a hub midway between the Dell and the Epson.
3. Verify that it is not the Epson that is problematic by playing a video source to the projector’s Video or S-Video port. If it is, then you have narrowed down the problem to the playing capability of the Epson.
Alternately if all else fails, perhaps you can try using:
1. a DVD player to the projector’s Video or S-Video port; and/or
2. a USB external DVD drive or a CompactFlash card (with a copy of the movie) direct to the 1815p
while settling the main issue.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 07, 2008 | Office Equipment & Supplies
Toshiba Satellite A215-S7422 Notebook Logo
225 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
