Question about Brookstone Big Blue Live Wireless Bluetooth Speaker
Unit charges up. turns on and off. just wont sync with any bluetooth device. Thanks
My nokia 220 wont pair with my parrot mki910 any ideas?
must sync blu tooth devices. see if it recognizes device, both must be on. and do it when you are not driving. at start up, before you drive. Thanks! safety first!! the radio might have an ID that must be entered into phone.
Feb 11, 2015 | Parrot MKI9100 Bluetooth Car Kit with...
Connect a bluetooth speaker to a tablet
Press the sync buttom if there is one on the speaker or make sure it's charged and turned on. Turn bluetooth off and on again and it should see available devices. If not goto setting of tablet find bluetooth and scan for sevices while speaker is in sync mode.
Pair and connect.
Enjoy the tunes.
Feb 01, 2015 | Visual Land Connect Android 4.0 Internet...
Customer help line
Here are the steps:
1. Make the partnership between the phone and the pc with the cable first and let it sync once.
2. Unplug the cable, turn on the bluetooth and make the pc and phone connect through bluetooth and save the device in the device list so it can connect everytime you want to sync without adding the device again.
3. Once they are connected to each other run active sync (with bluetooth still active) and press Menu-Connect via bluetooth. Here's the tricky part, it wont always connect. You have to do this a couple of times until you get a connection. For me its like 4-5 times and i get connected.
Thats it.
May 20, 2014 | Cell Phones
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
My brand new madcatz bluetooth headset wont charge, when plugged in the charging light is red, but it increases/ decreases in brightness after 4 hours it will not turn on or sync. This is the second one...
i just got mine and it when i plug it in to charge the red light turns on for like 10 seconds then turns off and it wont turn on so itss dead... return it?
Aug 29, 2010 | Mad Catz Bluetooth Headset for PS3
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Good luck from Headsets Direct!
Feb 14, 2009 | Plantronics Explorer 330 Headset
Bluetooth
I have a LG rumor phone from sprint and I am trying to program my bluetooth samsung WEP 200 and it is saying no bluetooth device found how do I set up the bluetooth I lost my instruction. The bluetooth was previously hooked up to the Razor phone
Sep 11, 2008 | Samsung WEP200 Headset
Wont initialize bluetooth
First make sure your blue tooth is 100%charged, go into the bluetooth settings and make sure it is registered on the device
Jul 16, 2008 | Insignia Sport MP3 Player
My phone wont locate my LG bluetooth.
Just because your phones Bluetooth option is turned to on doesn't mean it's searching. I would try going in to your device history and clicking on new device while your Bluetooth is in pairing mode.
Aug 08, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Bluetooth
You have to sync it with other device. Open the bluetooth settings on your phone and enabling (turn on) it. The universal code is 4 zero's (0000) to sync. Make sure the other device the bluetooth is turned on too. Good luck
Aug 06, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Brookstone Big Blue Live Wireless Bluetooth Speaker Logo
29 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
