Question about Casio G-zone Commando
Broken charger port
Phone charger port is broke battery is dead how can I retrieve my numbers
    Sergeant:
    Champion:
  • 317 Answers
You could use another phone of the same type to charge your battery there. Or a charged battery from another phone.
Posted on Dec 30, 2013
It wont charge
it could be three issues. 1.) The battery is dead. 2.) The cable charger is a cut wire or is faulty 3.) The charging port on your phone is broken and not delivering power to the phone. If it is the battery or cable, you can purchase new ones from many online sites, such as Amazon. If the charging port on the phone is broken, you must call your cell phone provider and let them now. This way they can send you a replacement as soon as possible!
Oct 19, 2012 | Nokia 6350 Cell Phone
Car charger broke off in side charging port. Cant retrieve info until it comes out. How can I take it out or take it apart?
Taking the phone apart wont help you, so don't do it. if it's a round power plug, a drywall screw will get it out if you twist it into the broken plug. For micro usb plugs, Wear safety glasses, and lever it out with the corner of a razor blade. Use gentle pressure, and go slow.
May 06, 2011 | Cell Phones
My phone wont charge
there could be many reasons for such a problem, charger related , and device related, so you have to check the following:
-first, you should check the power socket, it might be the reason why the charger is not charging your mobile phone.. try to insert it to many several power supply sockets..
-second if you tested it and it did not work; the charger itself might be broken, try to attach it to another mobile phone and see if it will charge or not, and try another charger to be attached to your mobile phone so that you will figure out if the charger is broken or not..
-third, assuming the charger is perfectly functioning, it is more likely that the battery is dead, every rechargeable battery comes to an end someday not able to be recharged having its chemicals consumed or changed, so that the easier way is to be replaced.. BUT, if you put that battery in a similar compatible mobile phone then tried to recharge it and found out that it is been recharged successfully, that means one thing that the charging port (where you connect your device with charger) is malfunctioning or broken so that it does not joint the charger with the battery..
Mar 26, 2011 | Cell Phones
LG Rumor phone charger receptor broke, how do I get the information in the dead unchangeable phone out of it to new phone?I see that this was a problem as the new Rumor phone has a USB port for the...
get a desktop charger and use it to charge the battery of your LG Rumor that its charger receptor broke.
Once the battery is full, you can then turn on the phone and get the information needed on the phone.
Check the link below, in order to have an idea of what a desktop looks like.
http://www.chinawholesalegift.com/Mobile-Phone-Gifts-and-Accessories/Emergency-Mobile-Charger/Desktop-Charger-103153420.htm
Good luck.
Apr 29, 2010 | LG RUMOR Cellular Phone
My Audiovox 8910 will not turn on evenafter buying anew battery
This is not likely a battery issue but is indicative of a phone that has gotten wet or has been infected with a virus or has other software issues. We work on cellular phones and would be willing to look at your phone to see if the phone numbers and pictures can be retrieved. Call 1-800-297-5550 and speak with Debby, 9 - 5, M - F, EST for shipping info. You can also contact Audiovox in NY to arrange for out-of-warranty repairs but they will not save your data as a part of the repairs.
Oct 16, 2009 | Audiovox 8910 Cellular Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Verizon Wireless EN V LG needs help
you can get the new piece of the charger port & can be replaced that by soldering the wire to the circuit board ........
any way the charger ports are available at very very cheap rates ....
buy the one which is compatible for your phone & replace it ......
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 07, 2008 | LG enV VX9900 Cellular Phone
Charger port on phone busted
I don't know what you want to hear. If the USB port is broken off, you will either have to get a new phone, or open it up and solder it back on. There are probably 4 "feet" at the corners of the USB port that broke lose from the board and you will need to reattach these. Alternatively, you could find the same phone on eBay that has a broken screen or some other problem that leads you to believe it has a good ESN and a good motherboard. Buy that phone and swap the entire board out. RadioShack has a good tool kit that works with most mobile phones, it's about $15.
Jun 13, 2008 | Motorola Mobility V325 Cellular Phone
Charger port problem
http://www.accessorygeeks.com/universal-travel-charger.html
or google BTC-UNI
iT'S little cheesy but hey for $10 and free shipping I can eat a lot of cheese.
Just plug your battery into this little clugy thing, plug the thing into the wall, wait until battery is charged and then put your battery back into your phone...presto...for this kind of money who cares if the VX9900 has a dead battery charge port.
I bought two, they were on sale for $7 each. It's ugly and takes a bit of patience but it works.
Feb 26, 2008 | LG enV VX9900 Cellular Phone
Phone Not Turning on.
it's one of three problems, 1. your battery is completely fried and you need a new one. 2.your charger is fried and you need a new one 3. your charger port on the phone is broken and you need a new one. If it's number 3 I would just get a new phone as replacing it is a major hassle
Aug 06, 2007 | Motorola Mobility RAZR V3
Casio G-zone Commando Logo
91 people viewed this question
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Josh Whitehead
Josh Whitehead
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
