Question about Samsung Prostar DCS Phone
Power failure-probably bad ram bu battery- appears to have lost all ram data. Co rings on only one station-all others almost dead.
Power failure and looks like the ram battery is bad.lost all ram data. only rings one station and all others almost dead.
My HP G60-230US Computer will not start. The computer is a little more than 2 years old. Every so often when I would start the computer it would say "No boot device found". I would restart the...
sounds like your motherboard malfunctioned. the board was probably starting to go out. thats why it would see the hdd then not.
you sound like youre familiar with computers. you may want to invest in diagnostic cards to troubleshoot problems like this. theyre fairly inexpensive on ebay. basically you insert the card into pci slot and it displays an error code. then you look up the code in a book. works like the obd2 reader for your car.
good luck
Feb 28, 2017 | HP G60-230US Notebook
HP Pavillion dv6704nr. All the lights flash when the power button is pressed, but it will not power on. I pulled the hard drive and copied the user's folder to a backup device on my pc. There we...
NO BIOS screens, fan isdead, wont blow?
pulling battery is always first.
so its not that.
power pack puts out 19vdc is next
then what?
pulled all ram or 1 of 4, did you try them all 1 by 1, not running
0 ram as that kills it dead. 0 ram would but the PC in to blink code errors mode.
do this yet?
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01732674
pulling ram will set blink error 3.
per that page, and does on all mine. (have many)
continuous blink is power PACK NO GOOD.
that page is very good, only misses one thing,
checking for 19vdc to the mobo with meter, but most shy away for doing real tests. so... they skip , that,
power packs have many failure mode,(im an ET)
1: dead.
2: WEAK (LOW VOLTAGE)
3: NOISE. (RIPPLE OR WORSE)
4: INTERMITTENT.
5: THE RESET LINE FAILS. (tells PC early power failed at wall,so can lie and make PC run on battery all the time.until it dies....)
6 or someone using the wrong watts pack, 65watts minimum.
Apr 04, 2017 | HP Pavilion dv6704nr Notebook
The sound works, so we can talk to somebody who rings, but there is no more video
Recheck ur video camera and wiring Yet?Security video devices that lost video are most likely have a bad or dead video camera or a lose and a dead wiring connections.
May 07, 2011 | Aiphone GH-1KD 3.5" clear VIDEO HANDS-FREE...
The screen is black when the Power button is turned on. Two of the buttons, caps lock and scroll button, keep blinking every 3 seconds. Also, the **** drive keeps making noises when the computer is turned...
If you have a desktop computer but listing it as a laptop with a problem you will get the wrong information back to repair the unit so you need to take this out and resubmit it as the proper unit before anyone can give you the correct information!
Sep 20, 2017 | Compaq Presario S6500NX (DQ181A#ABA) PC...
Settings lost when powered off. My Harman Kardon AVR 300 forgets all its settings when powered off. All radio station settings are lost, but also the input selections eg. cd=optical 1 etcetc. I guess there...
Most of these HK receivers have a 3.6v rechargable battery on the front panel board. If the battery dies, you lose memory when it is turned off/unplugged/power failure. The battery is soldered on the board. Not replaceable by the user unless you are a tech. It should keep memory if left in standby.
Mar 14, 2010 | Harman Kardon AVR 300 Receiver
Data missing - Ipaq model HP5555 - did not do hard reset
I'm sorry but the HP Ipaq 55xx series store data on a volatile ram based memory. Unlike a nand flash (like usb sticks, memory cards etc) this memory will hold data only as long as it's powered on. If your main battery gets empty you should still be able to retain your files for some 10-20hrs with the backup battery (if it's ok itself and not depleted). After this time the power to the ram memory is cut off and all data is lost.
The problem you face is somewhat related to that backup battery, as it appears it's unable to do it's job and maintain the power to the ram memory at least some 10 hrs. You should have that battery replaced.
There is no way to recover the data from the ram memory as it is stored as an electric charge over some memory cells in the ram chips. When there is no power, these charges dissipate and the pattern is lost.
I'm sorry for having to give the bad news.
Bogdan
Jul 03, 2009 | HP iPAQ H5555 Pocket PC
Dell 1505 Inspiron... Dead?
Motherboard failure, you can buy one on Ebay for about $100.
To confirm, remove RAM, Drives, battery and wireless cards, see if the LED indications change. If no change, then the MB is confirmed bad. If they change, add 1 RAM module back, see if the system will post enough to get into BIOS. If it does, add other RAM module. Keep adding items, (Wireless, battery, CD Drive, then HDD) and ID the one causing the failure.
Jun 09, 2009 | Dell Inspiron 8500 Notebook
Lost data
Sorry to say your data was stored in ram memory and when the power is cut the data is gone forever, there is no way to restore your data from ram memory ones it no longer has any power.
now that it has power again the data will stay in there. So I recommend you use a memory card to store your data, as a harddrive so you wont loose your files. Remember to perform backups also so the device can be restored, incase another power failure.
May 31, 2008 | Compaq iPAQ H3955 Pocket PC
PROGRAMMING
You have to get into your database programing "Feat, #, * " Says enter password, Default is 00000000. Enter into "Staion" then where it says "Show sta" enter 11,12 13 etc. "show" scrole to "CO Line Ring Assignment" Enter "Both" on each station you want to ring. Station #10 is the only default station that will ring without reprogaming the other ones to ring along with it. Hope this helps.
Oct 10, 2007 | Vodavi Starplus DHS 7312 Enhanced Phone
Loss of data when battery goes dead?
-are all pda's this way? All PocketPCs are this way. I don't own a P**m so I can't speak to them. -When the main battery depletes to the point where the unit shuts off how long do you have before data is lost? Until the backup battery dies. -Is the backup battery just used when changing main batteries or does it take over when the main battery goes dead? If so how long do you have before it is dead? I've never had it happen, so I cannot say how long, but if you continue to try to use the PDA on the backup battery it won't be long (minutes) if it even lets you do that. The backup is there to bridge over battery changes and to act as a safety net if you run the main batteries totally flat. -does the backup battery recharge or does it have to be replaced? Replace. -with a fully charged unit how long can it be left off before data is lost? Depends on the machine. Most of us leave the thing in the charger overnight every night, so this issue doesn't come up. You could try an experiment for 1, 2, 3 days, looking each day at the battery remaining and work up an estimate. I would expect maybe a week or more. Remember, even "off" the machine is still drawing power to maintain the RAM memory.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Samsung Prostar DCS Phone Logo
62 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
