Question about Lands Phones
No dial tone cant make calls
No ring tone and will not receive calls. base works and batteries charged. will make internal calls from phone 1 to phone 2 and 3 using cables that came with phones and all displays ok on all three phones.this is a brand new set of three phones. no dial tone out and no ring for incoming calls.
    Top Expert:
  • Lands Phones Master
  • 45,139 Answers
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Posted on Dec 30, 2013
  • 1894 Answers
SOURCE: no dial tone and "line in use " message
the wire that is used to connect the line to the telephone is not proper...
Posted on Mar 02, 2008
mattozan
  • 555 Answers
SOURCE: GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
Posted on May 21, 2008
  • 37 Answers
SOURCE: no dial tone - phone rings for incomming call but I can't hear or talk
This can be a problem with your handset.
Have you tried a different phone in that same jack?
Posted on Apr 19, 2009
Coleman37
  • 337 Answers
SOURCE: I've got a Panasonic 5.8 GHz Digital Gigarange
I would try to reregister the handset. It's on page 40 of the instruction manual. Here's a link to the manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG5421S.pdf
Posted on Mar 10, 2010
Try the simple things first. Try a different phone. In my case, I had the phone company check - outside was fine. After two hours my phone worked. I figured out what happened in my case. Both phones were dead (battery). I think one died with the phone off the hook. once the phones were fully charged, the phone worked.
Posted on Mar 29, 2010
Why is there no dial tone on my phone?
most likely phone line down notify phone company
Aug 25, 2017 | Computers & Internet
May 21, 2008 | Uniden Cordless Phone
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
No dial tone phone jack tested ok phone rings incoming call when you pic up nobody. changed battery still no dial tone or conection on incoming call
This is caused by a failed wireless signal transmitter in the base station or a failed wireless receiver in the handset, these phones are not repaired unless they are under warranty, so all you can do is replace it, this is the #1 PROBLEM WITH ALL CORDLESS PHONES.
Mar 22, 2011 | Clarity C410 Cordless Phone
I cant get my phone to work. I get no dial tone and it says connecting but never connects. incoming calls ring but i cant answer
dear
There are a number of things that could be wrong. It really depends on what kind of circuit you have. Is it strictly copper or does it come from a pair gain system? I have had trouble calls for this very reason and I isolated the trouble to a pair gain card in the field. Have you tried dialing out when you have no dial tone? Most people don't realize that dial tone is not a requirement to make phone calls. It's an added feature that lets people know that it's working. It could also be a high open. Just means that one side or both wires of the pair are close to being broke and sometimes very hard to see. I would keep calling because they won't know you have trouble until you do so. Plus you will have documentation that it's an ongoing problem. Good luck.
or
Another possibility is a shunt caused by spiders or whatever. These can get much worse when it get's wet. They might clear on a ring too.
I'm voting for number 1 unless there is more info provided.
I'd provide Verizon with the RENs of all the phones added up. There is probably a 1/2 ringer or (1/2 REN) in the NID.
You need to determine if it's inside or out.
Jan 05, 2010 | Uniden 5.8GHz Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
No dial tone at all
if the non-cordless phones are ok, it sounds as if the cordless handsets are the only ones not working, have you charged the batteries on those handsets ok and are there any signs if life, eg lights or on-screen messages ? Are they switched off ?
If there are signs of life, check the level of charge, if dead completely, take it/them to the main unit and put on charge for about 10 hours, if they work for only a short time and you have had the phones for a few years, then you will need to replace the re-chargable cells as they don't last forever and they are not holding the charge.
Hope this has given you some clues.....
Jan 16, 2008 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
528 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
