It will not open eveny time i get in it
If the Passcode feature is enabled it will only prompt at a specified time interval or every time or disable it and not at all. So there is a System Setting you can change to make it what you want. If you need further help with the passcode settings, let me know. I think you just need to change the settign to everytime from some 1-15 minute interval it is probably set to.
If you repeatedly enter the wrong passcode, your iPad will be disabled for longer intervals before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect it to the computer with which you last synced it.
Note: You can configure your device to erase itself after ten consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock.
If you cannot remember the passcode, you will need to restore your device using the computer with which you last synced it. This allows you to reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be present.How to Unlock an iPad with a Passcode
1. Connect iPad to your computer.
2. Select iPad in the iTunes sidebar, then click the Summary tab.
3. Click "Check for Update." iTunes tells you if there's a newer version of the iPad software available.
4. Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you back up iPad when prompted. When the iPad software has been restored, you can choose to set up iPad as a new iPad, or restore your music, videos, app data, and other content from a backup.Please additionally note that Apple staff also cannot unlock an iPad for you without restoring the iPad, which will erase everything on it.
