Question about Stihl Garden
Cracked gas tank stihl 038 av
Cracked fuel tank. Need to disassemble.
  • 31 Answers
If you clean it with a wire brush. you could try J-B weld, gas doesn't seem to bother it
Posted on Jan 17, 2014
Testimonial: "Thx did buy some JB weld definetly going to use,the cracks in a location where I have to or should remove the fuel tank for better accessibility .will do.just a little hesitant ,never did before. Thx for the response."
rwvanlue
  • 486 Answers
SOURCE: stihl 038 av
Basics to check for 'No-Start' condition:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Dec 04, 2009
dontbother10
  • 2220 Answers
SOURCE: setting the points on a stihl 038 chain saw
If equipped with points:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d7d12fb678653bf688256ba20049bcdb?OpenDocument
HTH
Lou
Posted on Dec 25, 2009
dontbother10
  • 2220 Answers
SOURCE: how to change fuel hose and filter on stihl 038
A hooked piece of wire through the gas cap will allow you to withdraw and remove the filter. A typical fuel system and a couple of suggestions follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
At this point I like to provide an IPL that displays all fuel components and makes a good disassembly guide. Stihl considers all OE parts, IPLs and shop manuals proprietary. When they find an on-line source they force it be removed. Please contact them and request an IPL here:
Stihl USA Contact Us
http://www.stihlusa.com/contact.php
When they decline your request Please file a complaint.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Feb 28, 2010
dontbother10
  • 2220 Answers
SOURCE: Stihl 028 Gas Tank off?
Any other manufacturer I would provide a link to an IPL. Stihl considers them proprietary.
Go here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A bunch of folk that enjoy all chainsaw. Please try search, find an applicable thread and join the conversation.
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
Search for your saw and send a PM to an active member that replied to a similar request works best.
Lou
Posted on Mar 18, 2010
dontbother10
  • 2220 Answers
SOURCE: stihl 038 av super chain
Afternoon Mac;
I am going to give you a qualified YES.
It is possible with Husqvarna and Echo.
All Stihl parts are proprietary and new OEM parts must be purchased through a local Stihl dealer. A phone call to your local store will answer your question and whether they have one in stock. If you do not want to utilize your local dealer eBay for a used part is your best option.
If you have more questions or need additional help please reply below and I will get back to you. HTH
Posted on Aug 30, 2010
What carb fits a 038 av stihl
google --stihl carby for model 038 and a list will come up
look on the carby as it will be either stihl or yamma as stihl owns yamma carbys
Oct 25, 2017 | Stihl Garden
Were does the small vent tube out the top of the gas tank go on a stihl 029 farm boss. mine broke off flush with the nipple and is leaking gas badly.
This is very important that the connections are correct. The fuel is pulled through the carburetor to purge all the air before starting. Air will keep the fuel pump from refilling the carburetor when attempting to run.
A filter is attached to the end of the fuel tube located in the tank. This hose is the fuel pickup and passes through a tight hole in the tank. The other tube is the return also from the carburetor and is open on the end returning inside the tank also fitting through a tight hole in the tank.
It is easy to reverse these tubes. If one has cracked it is likely all need to be replaced. Take pictures and take notes before starting.
Reversing the hoses allows for unfiltered fuel to fill the carburetor with the result of plugging the jets.
Feb 25, 2017 | Stihl Garden
Fuel lione and filter came off in the tank
This is a simple repair.
1. Drain tank save fuel can be used again
2.Purchase fuel line replacement kit Lowes -Home Depot
3.Kit needs to contain feed wire and gas hose.
4.Disassemble cover to reveal fuel line connection to carb.
5. Feed wire from kit into fuel tank through fuel line hole.
6. Install new hose over wire connecting end into hook at end of wire
7. Pull hose through tank up to the carburetor
8. Remove wire and connect filter and hose to carburetor
9. Replace gas into tank, Ck for leaks
Nov 15, 2015 | Stihl HT101 Pole pruner
Stihl 012 av fuel lines
The 2nd line might be a vapor return line back to the fuel tank? I've dealt more with repairing bigger saws more than smaller ones. You should go to a Stihl shop&take a look at chainsaws about the same size as yours&take off the air filter cover&look to see where the carburetor lines go.
Aug 01, 2014 | Stihl 011avt Brake Handle 009 010 011 012...
038av fuel tank vent line
What's your question about this item? Regarding what?
Feb 07, 2013 | Stihl 038av "metal Tank" Screws Case 038...
Stihl 038 super av starts hard, once started runs great till its warmed up then dies and wont start
check the seals on the crankshaft for a leak and the ignition module for a loss of spark as it warms up.
Dec 07, 2012 | Stihl 038av Case Buffers Caps / Plugs 2...
How to change fuel hose and filter on stihl 038 chainsaw
Lou
Feb 28, 2010 | Garden
Stihl 038 av problem starting saw.
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Dec 03, 2009 | Garden
Garden Logo
153 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
