Question about Car Audio & Video
One of my headrest tv's be blinking why - Car Audio & Video
How do I adjust the front headrest on my 2009 Lincoln MKS so that they do not tilt so far forward?
I turned my headrests backward. Worked great. In fact, I wonder if the engineers designed them that way but the production guys build them backward???
1) Tilt the seat way back to allow room to remove headrests, 2) Press and hold both headrest release tabs at the same time and have someone else pull out the headrest completely, 3) turn the headrests backward and insert into the two headrest guide slots (headrests fit the same either way). 4) No more pain in the neck !!!
Caution: I do not know what this does for whiplash injury protection but it seems OK for my own comfort with the solution. And it beats the pain in the neck caused by the bass-akwards design.
May 13, 2012 | 2009 Lincoln MKS
Removing the headrest on a 2000 ford mustang gt
1. Lift headrest and headrest support bars trim all the way up.
2. Insert tongue depressor (or slim jim) down the front side of the headrest bar. Push depressor down as far as possible. When the depressor is beneath the headrest trim piece, push headrest all of the way down.
3. Lift headrest to remove.
Jul 05, 2010 | 2000 Ford Mustang
Headrest Removal
Lift the headrest to the full upright position, and you will notice on the plastic piece where the headrest rod goes into, there should be a small hole in the plastic piece, insert a small tool or paperclip, and then pull the headrest off
Sep 24, 2009 | 2001 Pontiac Grand Prix
Dark screen on my headrest tv
its defective, need to be repaired or replaced
May 29, 2009 | Car Audio & Video
Front power headrest removal
hello,you need to remove your rear seat,,look for your your headrest valve ,there is a lock pin with tension clip in headrest rod ,remove the pin,try to remove your headrest slowly,ty
May 07, 2009 | Mercedes-Benz 560-Series Cars & Trucks
Trying to remove a headrest from passenger seat in 2007 xc90
push & hold button on headrest while pulling up
Feb 19, 2009 | 1990 Volvo 740
Removal of headrest on 2005 Ford F150.
The headrest has on obvious button to adjust the height and another button kinda hidden to remove the headrest. The black plastic ring at the base where the metal poles insert into the seat is where the two buttons. You probably noticed the obvious on that sticks out of the side of one of the rings. The other plastic ring contains a similar button that is not noticeable due to it being flush with the side of the plastic ring. Adjust the headrest to its highest position, then locate the "hidden" button on the other plastic ring and depress it while lifting on the headrest and it should come out.
Dec 11, 2008 | 2005 Ford F-150
Installation of headrest dvd
yes the screen has to sandwich the material from the headrest to hold it in place.....
Oct 10, 2008 | 2006 Audi A8
HD-95 Headrests
i ran 3 wires from my amp and the rca jacks to the tv and they work fine. a hot ground and remote.
Apr 09, 2008 | Power Acoustik HD-95 Car Monitor
Video output not working
it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
Feb 25, 2007 | Kenwood DDX-6019 Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
