Question about Audio Technica ATLP120USB Turntable
Too much bass
The turntable produces too much bass on playback. I've tried different records and different speakers with the same result. The tone controls on my receiver provide some relief but not much.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Audio Technica Master
  • 924 Answers
Are you possible hearing a low frequency rumble out of it, thus making it sound like too much base. This is known a Acoustic Feedback. It is caused by the speakers producing too much volume, or the base turned up to too high. This condition is possibly linked by turntable being located to near the turntable. I would have to know this first.
If you more more assistance, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Nov 27, 2014
    Sergeant:
  • 302 Answers
I didn't know that a turntable had bass control on it. If it has why not turn the bass down? I think it is your receiver not the turntable
Posted on Dec 30, 2013
When playing LP the sound is bass heavy, but when playing a cd, the sound is perfect.... any suggestions?
The record deck is played through a separate pre-amp to all other functions, so it therefore could be a fault in that pre-amp, but I doubt it. You can fit a wide verity of cartridges in record decks that will each give a different response to the sound. But first check that the cartridge connections are correct. Try swapping them around, it might change what you get. But it could simply be that you have a cartridge that produces a lot of bass. Changing the cartridge to a high quality recommended type - by say some hi-fi buffs website or magazine, might solve the problem.
Apr 14, 2015 | Pioneer PL990 Turntable
Tip
Tip for your home theater system: tweak your subwoofer level and crossover...
An important tip regarding your home theater system is to Tweak subwoofer-level and crossover controls:
Test tones and meters aren't the final arbiters in the bass department. If your sub's bass is boomy, thick, or uneven, first try lowering its volume --most people complain that their sub louder than necessary. Next, if your satellites are very small, the crossover control should also be set to its midpoint or higher. Bigger speakers produce more bass on their own, so they sound best with the sub's crossover knob set at or near the bottom of its range. Finally, moving the sub out of the corner and closer to one of the front speakers may produce smoother, flatter bass.
on Aug 23, 2010 | Audio Players & Recorders
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
When I record a vinyl record one of the stereo sound tracks sounds feint.
There are several different causes for this issue - assuming the balance for other programs works as expected. The easiest to check and fix is the "Master Volume Control" You access this on a Windows PC by right clicking the Speaker Icon in the system tray (lower right corner of the screen). Select "Open Volume Control" Next,you'll see a box with Master Voume, Wave, CD, Wave, etc. These are the playback volume controls (shown below).
We need the Recording Control. Click "Options" --> "Properties" and select "Mixer Device". A drop down box should appear offering an choice of Input or Output devices. Choose Input. "Recording" should be selected in the "Adjust volume for" box. Place a check mark in each of the input presented. Mine looks like this:
Click OK to get to the Recording Control box below.
Here, make sure the BALANCE indicator is centered between the two speaker icons and the correct input has been selected - in this case, "Line Volume". Yours may be different. If already centered, go to the next step.
If the input levels are balanced, there may be a problem with the input cable. Try replacing the audio cables and try again. If your turntable uses a USB type connection that is molded to the turntable, you won't have this option.
If still no change, try connecting to another computer. If the problem is still present, it is in the turntable, somewhere between the last cable you can change and the stylus / cartridge. A stylus or "needle" can be replaced for under $10 or so (it's been a awhile since I priced these - so don't quote me) and simply plug into the cartridge. The cartridge is more expensive, but not too bad. Most cartridges simply plug in to a jack on the tone arm. Stylus and cartridge replacement is a do it yourself job and does not need to be done professionally - unless of course you want to have it done for you.
If none of these solutions work, there is some other problem inside the turntable. Most times, one of these steps will solve the problem. I hope this helps and good luck! Please rate my reply, thank you.
Mar 01, 2011 | Computers & Internet
Trying to install a ion iTTUSB on computer but not
READ your quick start booklet. You need to go to control panel, open sound, there are three tabs- choose playback and make sure that the selected speaker is not USB Audio Codec-choose your speakers. In the Record Tab selcect USB Audio Codec.
Dec 15, 2009 | ION Audio iTTUSB Turntable
I need advice on how to connect my very old BOSE 901 (with active eq) to this device: Martin Roland MA 3000K I see pre-out and pre-in but cannot locate main-in. Please help here is the back of its image:...
As you probably know, the Bose 901 Active EQ is there to modify the frequency spectrum fed to the 901's so they will produce a flat response. Without it, they sound acceptable in the midrange but lacking in bass. Since they have no woofers or tweeters, the modification is drastic and should never be applied to non-Bose-901 speakers or they could be damaged.
This setup should work for mixing and playing but I'm not sure if recordings directly from the unit's REC Out or Line Out would have the Active EQ effect on them. You'll need to perform a few tests to see how it all works for playback AND recording.
Remove the jumpers for Pre In >> Out
Insert the Active EQ in their place by running:
1. RCA cables from Pre Out to the Active EQ In (From Aux, Tape Out)
2. RCA cables from the Active EQ Out (To Amp, Tape In)
Use ONLY 901's on this amp with the EQ.
The Bose Active EQ has its own Tape Rec/Monitor loop to replace the one it normally occupies in a typical receiver application, so if you wish to record your mix you should use those connectors for your tape deck and there will be no problems with the Active EQ effect being recorded. The Monitor Tape/Source switch on the EQ functions just like a typical Tape Monitor. For playback of the recording, switch it to Tape.
The manual, available at http://lib.store.yahoo.net/lib/acekaraoke/MA3000K.pdf
doesn't get into any detail on the innards of the mixer.
In a typical integrated amp or receiver, the jumpers removed are between the Preamp Output and the Main Amp input, but BEFORE the amp's volume and tone controls, so manipulating them would not affect a recording. You should experiment with it by making recordings through both and adjusting speaker volume to see if it changes.
I would be curious to know what the functional difference is between the designated LINE Out, REC Out and PRE Out jacks in that regard. Normally, Line Out and REC Out will not vary with amp volume, but I expect in this mixer it does, or you wouldn't be able to control the volume from it. Experiment.
Of course, you probably want the mixed effects to be recordable, so I assume they'll appear at all outputs. Play back the test recording (at an initial low level, just in case) and see if you can detect an exaggerated low end (due to the 901 bass boost being applied in recording AND playback through the 901's. If the recording volume doesn't vary with speaker volume and the playback sounds as flat as the recording you're good to go.
If there is are volume variations or an additive effect, you may have to draw the REC Out to the deck's input and run the deck's output to the Tape In on the 901 Active EQ, monitoring only on deck playback.
Dec 02, 2009 | Bose 901 VI Main / Stereo Speaker
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
Tonearm/ scratchy audio
The transport screw is just for stabilising the suspension for moving the turntable. Just put it in the position that allows the turntable to bound up and down a bit when you poke it.
As for the skating of the tonearm, it's just that the tracking force is set too high. I don't know your turntable, so can't tell you quite where the tracking force adjustment is, but it's likely a dial close to where the tone arm pivots. A test record (with test tones) is a great way to adjust that, but otherwise repeated listening to a record will help you - make sure that the loud parts of a track distort equally on both speakers.
See also http://www.turntablebasics.com/advice.html
Mar 21, 2009 | Excalibur RD50 Turntable
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Audio Technica ATLP120USB Turntable Logo
75 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Michial Gueffroy
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
