Question about Sewing Machines
Knob at end of machine very very stiff and won't sew
  • 89 Answers
You probably need to take it to a repair shop. Always clean first. Most problems are cleaning issues. Look for a thread or lint caught in that area.
Posted on Feb 01, 2014
3 Suggested Answers
dupina
  • 110 Answers
SOURCE: viking sewing machine 21E
Yes you can oil it, but you need a solvent, like terpentine, to clean the inside of old grease and sticky oil. Best done by a authorised technician.
Posted on Dec 06, 2007
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
How do I repair the stitch changer on my Husqvarna viking
if the stitch selector is stiff, don't force it, some small parts that are no longer available could be damaged. take the machine to an authorized Viking repair center for evaluation.
Feb 12, 2015 | Husqvarna Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
Wound a bobbin now machine won't sew
after the clutch knob inside the handwheel is tightened,,,
did you push the bobbin spindle back to the left?
Oct 12, 2012 | White Sewing 1766 Mechanical Sewing...
Kenmore Sewing Machine 385.18221
Probably best to take it to a service technician.
Jun 12, 2017 | Kenmore Sewing Machines
CI just got my sewing maching six month ago and now for the first time it giving me problem . whenever im sewing the fabric won't move please please !!! help me to fix the problem.
in the needle plate area you'll find the feed dogs, they move the fabric forward as you sew, they should be up to sew . most sewing machine have a lever or knob that can be moved to change the feed dog position, unless then knob is broken
Aug 04, 2011 | Sewing Machines
How to do the washers go in behind the crank knob
Hold the machine on its end then place the washer before screwing in the knob. I suspect the washer falls off everytime you try to attach the knob. Let gravety do the work
Dec 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Viking sewing machine 21E
Dec 06, 2007 | Husqvarna Designer I
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
