Question about Pioneer AVIC-X920BT Car DVD Player
Pioneer avic x920bt turns on for a little while then screen begins blinking then turns off completely. unit worked fine for months, please help!
The splash screen comes up when car is turned on and seems to start normally, then after about 30min it begins flashing from the splacsh screen to black and then eventually stays black and will not respond to any buttons or touch screen. it will be like that for an entire day or two and then when i start up the car a day or two later it works agaion for just about 30mins before the problem repeats... i;ve had this system for a long time with no problems, please help!
hogan doan
  • 227 Answers
SOURCE: AVIC-N2 stopped working and wont stop flashing PLEASE HELP!
Sound like the ribbon cable because before breaking off completely the vibration of the engine can cause current to fade in and out(open and close circuit).
Posted on Jan 24, 2008
  • 5 Answers
SOURCE: AVIC-N1 opens to blanks screen and none of buttons work
It is probably the ribbon cable that you can see when the screen closes. This is a known problem and the part is sometimes hard to find. But is available.
Posted on May 26, 2008
SOURCE: Pioneer AVIC D2 screen won't open...
Oh, I have the same problem. What the hell is that? I like all the futurs that Pioneer AVIC-D2 has and I get this problem after three years use of this unit. Please someone from Pioneer technical dep. could help us?
Posted on Jul 16, 2008
SOURCE: Blank screen - but radio working
When park the car in the hot weather condition, the unit turn off by the thermostat to protect it from overheating. Once the unit is cool, restart the unit should resolve the problem. If not, disconnect the power from the unit and wait for 15 second before reconnect. Good luck.
Posted on Aug 24, 2008
  • 111 Answers
SOURCE: No picture on display, buttons dont work
The problem is the ribbon cable,and you right there is a recall for this model,you need to contact Pioneer at pioneerelectronics.com and they should repair it for you at no cost.
Posted on Dec 02, 2008
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
The car start, run ,and you can turn it off it take about 30min. Before it start back up.
Consider replacing the crankshaft positioning sensor. A crank sensor is an electronic device used in an internal combustion engine to monitor the position or rotational speed of the crankshaft. This information is used by engine management systems to control ignition system timing and other engine parameters.
The simplest and most obvious symptom of a failing crankshaft position sensor is the blinking "check engine" light in your car.
According to Do It Yourself.com "When the crankshaft position sensor begins to fail, the signal it transmits to the vehicle's computer begins to weaken. If left unattended, the signal will switch off completely. This, in turn, causes the car's spark plugs to die out, killing the engine. If you are having problems starting your car, it could indicate bad crankshaft position sensor".
Of course this may NOT be YOUR problem, but it sounds like it could be, doesn't it?
Feb 28, 2015 | 2000 Ford Contour
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
Avicx920bt screen dosent work
"Sometimes" will not make it easy--has it been dropped or jarred hard?
Dec 09, 2012 | Pioneer Avic-x920bt GPS Receiver
PIONEER RADIO NEED CODE
The code that came with it to activate it. It should be on a small card
Nov 25, 2012 | Pioneer Repair Fix Service For Avic-x920bt...
Toshiba Tecra M5 Boot Problems
man you push alt+ Ctrl +p so you can get it the Bios specially where has been saw it the flash cursor you will see now BIOS normally
Jun 30, 2012 | Toshiba Computers & Internet
MY pioneer AVIC-X920BT Makes a beeping noise when I touch any button on the radio is there any way to get rid of the sound?
there should be an option in the menu. BEEP ON/OFF. It is annoying i understand how you feel.
dreamsystems
link to pioneer support page: http://www.pioneerelectronics.com/PUSA/Support/Search?model=AVIC-X920BT+ download the manual.
Feb 16, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Processor fan runs really fast and I have nothing that shows on my monitor when I turn it on. My Video card is good. Any ideas?
When the power first turns on, the fan runs at maximum speed. Then when the motherboard starts up the speed drops and you see the splash screen, the POST information, etc. Your board isn't starting for some reason. You may have a power supply issue, something attached to the board (drives, expansion cards) may be holding the board down, or RAM that isn't working. Try clearing the CMOS memory and see if the board starts normally. Then disconnect everything except the power supply and front panel connectors, remove any expansion cards, take out the RAM and turn the power on. You should hear the beep error (usually a long beep) indicating "RAM not found". If you don't, the power supply or the motherboard itself is likely at fault. Otherwise you can begin reinstalling parts beginning with the RAM. Restart after you reinstall each piece, and if one of those is at fault the problem will come back and you'll know which part is responsible.
Jan 10, 2011 | Computers & Internet
I have installed an AVIC-X-920BT into a 2000 Toyota 4-Runner. Once installed, not all of the ICONS are available - example address entry on GPS (however, POI icons, etc. are lit). Any thoughts?
I think you have it hooked up correctly, but I would say that if some icons are missing, the signal may not be getting to the unit for the respective icons.
Jan 02, 2011 | Pioneer Avic-x920bt GPS Receiver
My ps3 has stopped turning on. The light turns to green, the console begins to start up, then it flashes yellow, beeps and goes to red.
My PS3 had the same problems. I found that if I disconnected the HDMI cable and installed the cable with the 3 phone jacks, Red,Yellow, and White, that it came on and has been playable since. Before that I got the YLOD, red screen display, pressed the on button for 3 beeps and got the reset. That worked for about 30min then went to a blank screen. Gave up and was ready to send it to the shop, but then as a last resort I connected the other cable and it has worked ever since. Must have been in the HDMI cable.
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
Pioneer AVIC-X920BT Car DVD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
