Question about Sewing Machines
Jones circa 1960's
The belt goes round when knob is loose but when knob is tightened motor runs still but belt won't move
    Champion:
    Habit-Forming:
  • 201 Answers
Please you have bought the correct size belt Or put in 2 or 3 drops oil on belt then you will start machine.
Posted on Dec 31, 2013
2 Suggested Answers
  • 1564 Answers
SOURCE: My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Posted on Nov 30, 2012
My vintage kenmore hand wheel was frozen now it turns manually but not when I use the foot pedal, then it won't turn
Either you will replace the belt or have to adjust the motor/belt tension.
1. The motor can be loosened by a couple of bolts. This allows the motor to be moved to adjust the tension of the belt.
2. The tension can be adjusted properly by turning the motor on with the foot pedal; low speed.
3. While the motor is running move the motor in a fashion that will loosen or tighten the belt. The correct location will allow the motor to run at it's highest speed.
4. Re-tighten the bolts and retest the machine.
May 04, 2017 | Kenmore Sewing Machines
My sewing machine stops after about 10 revolutions, the motor is till running but the needle does not move. any suggestions please ?
1. Loosen the screw on the front of the hand wheel, almost completely.
2. Now, tighten the hand wheel control knob. The needle should be able to move now.
3. Tighten the screw. Your hand wheel control knob should be able to be loosened for bobbin winding and tightened for sewing.
Just for information purposes: The hand wheel control knob is usually the small round knob on the front of the hand wheel and is also very shiny.
Oct 02, 2016 | Sewing Machines
How to replace red belt
It is probably the motor belt. The motor has bolts that are loosened that allows the motor to be tightened or loosened to the belt.
Loosen the bolts and remove the belt. Replace the belt.
While tightening the belt have the machine running so you can adjust the motor by slightly moving the motor to different places until the speed is the highest.
Aug 24, 2015 | Sewing Machines
Why doesn't the needle go down?
1. If the machine motor is running you can see if the bobbin winder is functioning. If so then you need to tighten the hand wheel lock.
2. If it doesn't work try loosening the screw on the hand wheel lock. 3. Try to tighten the wheel lock now.
4. Now, tighten the screw.
5. If it still isn't functioning you may need to loosen the motor and replace the belt.
6. Belt. Remove old belt. Put new one on while motor is loose. Tighten the motor while you keep the machine running at a slow speed. As you tighten the motor there will be a point the motor speed rises the most. Tighten the motor there and recheck afterwards.
Mar 20, 2015 | Sewing Machines
Janome jf 1004 motor running slow
The problem that I've had with most motors running slow is the drive belt is too tight, out of alignment or too loose. To adjust you need to have access to the belt. Notice where the nut is that holds it in place. Carefully, loosen the nut and slowly push on the foot control You will have to move the motor in different ways until you can notice the speed is at it's highest. This means to tighten, loosen or shimmy the motor to one side or the other. Be careful so you don't get hurt!
Feb 01, 2015 | Janome Sewing Machines
Clutch knob on kenmore 15814001 sewing machine will not tighten
Have you removed the inner wheel? If so you probably have put clutch spring in backwards. The washer like piece has to bent fingers that appear to fit in the center of the shaft. These should be facing out toward the tightening nut. Turn washer around and voila good to go.
Oct 17, 2014 | Sewing Machines
My Pfaff 130 will not sew when the foot peddle is pressed and the flywheel turns, but the big silver screw in the middle of the flywheel does not move. If I tighten the big silver screw and turn the...
Does the motor turn at all. Does it hum when turning it on. It may be burned or the pulley on the motor is loose. Tighten it up and that should get it . Let me know if that works.
Jan 31, 2013 | Sewing Machines
Nov 28, 2012 | Sewing Machines
I have a babylock 1556 and when I press the foot petal the belt turns, but it won't move the needle up and down. I took off the back so I could watch and see what was going on. I can see the belt...
On the side of the 'knob', look for another wheel that tightens against that, so it engages, that's what it sounds like. When that second wheel is loose, it won't run, it just spins. From the photo I can find of the unit, it looks like that second wheel is below it, but I can't be certain. Let me know how you make out. Please rate and comment, thank you,
Joe
Sep 04, 2011 | Baby Lock BL1556
The rod connected to the needle is not moving up and down anymore. I was sewing a straightline at setting 2 when the rod just stopped. We romoved the top and side pannel. Then we turned it on to see if the...
Easy fix is take to local repair person, but barring that you will need to look to replace the little knob so that it tightens down and grabs the larger knob. Sometime you'll need to try to place it on the machine a few different ways till it works right.
The little knob is used to disenage the machine for winding a bobbin. Add little bit of machine oil to help keep it loose.
Dec 17, 2010 | White Sewing 1766 Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
