Question about Amana Washing Machines
Cant remove the pump to change a belt
I cant romove the pump for my amana lwa50aw
I ended up breaking the pump. I found that there is no real trick, it just gets stuck on sometimes. I worked on removing it very carefully for a couple hours but in the end the plastic cracked and needed replaced. The pump cost me $48 to replace and then the rest was easy
Posted on May 25, 2009
Washer fills, agitates, won't spin. Makes buzzing noise. Amana LWA50AW
Most likely it could be the forward belt . When the machine is under load you hear a winding noise it sounds like the pulley belt tensioner. One other thing to check the rinse and hold button is activated as in the past accidentally people have switched it off.
Jul 26, 2011 | Amana 3.2 cu. ft. Top-Load Washer
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
The washing machine belt will move to agitate, but will not move to spin. The spin action burns up the belt. This is an Amana LWA50AW
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Nov 05, 2009 | Zanussi FJS1225W Front Load Washer
Amana washer LWA50AW
I had the same issue last year on y lwa50aw. It is the timer. Get the speedqueen version it is about $50 -$80 and aboyt 15 minutes to replace.
Apr 19, 2009 | Amana LWA40A
How to put on a new belt for Amana washer model #LWA50AW
I just did this today. You have to remove the motor. first start by removing the two hoses then remove the four 1/2 inch bolts that hold the motor/pump assembly. the wires are clippes to a bracket, pry that off removr the whole motor assemly with the bracket by pushing on the tub to manipulate it out. Then remove the three #25 torx screws that hold the pump to motor, remove the pump then route the belt onto the pulley around the inside pump mount put the motor back on the reinstall it the way you took it off. its not that bad (for the first time ever working on a wash machine). I hope you dont have the problem I do, the belt slips in the spin mode - that is probably why the belt failed in the first place I am still trying to find a solution to that. if you just have a failed belt, you will be just fine.
Apr 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Amana Washer LWA50AW doesn't spin
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Feb 26, 2009 | Amana ALW480DA Top Load Washer
Washing Machines Logo
298 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
