Question about Garmin StreetPilot C330 GPS Receiver
Gps comes on to say street pilot then shuts off over and over
Street pilot c 330
was updated not long ago.worked fine for past saturday.went to turn it on today and the street pilot screen comes on then blinks off.
I also have this problem with shutting off when turned on. I have 2 of the same C330 garmins, i took the window suction cup device from the other unit and it works fine. I am in the process of trying to find this part to replace on this one. It is not getting the connection to recharge, therefor it shuts off. Hope this helps you.
Posted on Jun 08, 2009
I had the same problem until I looked at the end of my car charger that plugs into the cig. lighter. I noticed that it had came apart. I had to find the fuse and other parts and put it back together.
Low battery, charged it up works fine now
Posted on May 20, 2009
Street pilot 7200 keep shutting down after a download
your on board battery my be bad contact there website for more information and tech phone # fo help
Jul 27, 2009 | Garmin StreetPilot 7200 GPS Receiver
Garmin street pilot c330 goes on and then goes off
Try to charge the unit for 4 hrs by using a wall adapter and then try power on it again and if still the same after you full charge the unit try to contact the manufacturer check if there is a latest firmware update for the unit.
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
StreetPilot C330
Go to www.garmin.com and read about "Map Updates" Enter your unit's serial number and see if there's a newer map available. It will explain about how to buy and install the update.
Jul 01, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
Jun 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Jan 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 330 street pilot keeps shutting down, only had it 1 year
Have you tried charging the unit on the computer? If not, try doing this for a few hours. Sometimes it can help.
Nov 04, 2007 | Garmin StreetPilot C330 GPS Receiver
Repair/replace
repair street pilot 330 electrical short?
Oct 28, 2007 | GPS
Take the navigator 2 a repair center, because somethin that new, shouldn't happened unless it hasn't been charged for awhle after being in the box on the shelf
Oct 14, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
244 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
