Question about Shawn kemp skybox 1995 hoops power
Television is showing 'out of range' and nothing is happening
Tried switching everything off to start again but still nothing
    Problem Solver:
  • 5 Answers
I can think of a couple of potential issues that might be creating this problem:
1. You have a playing card and no matter how long you look at it, the image will not change.
2. If you are using this trading-card TV in your car, it is probably not a mobile trading-card television, thus the 'out of range' message.
3. As a trading-card, it is not electric, so whatever you are doing to switch it off isn't having the desired effect because as a trading card there will be nothing different when you 'switch everything off.
I recommend you think differently about your trading card in order to fix this problem. It is a card, not a TV. If this fails, you can buy a new one on ebay for under $2.50, but I don't think it will work any better.
Posted on Dec 30, 2013
Does anyone know if it's possible to fix a water damaged panel? (samsung ue55d6327) The screen lights up and shows picture but with distorted coloring around the affected area.
Hi Ola,
This is the sad story of many a Tv owners. I have seen a number of cases like this and I am sorry that there is nothing you can do about it. The liquid damages the electronics on the strip attached to the panel and that can not be repaired. You are right that nothing happens to the LCD panel but it can not function with the damaged parts.
Jan 04, 2016 | Samsung Televison & Video
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
Kird801hss- vent will not raise
I had the filter micro switch problem as well. After disassembling everything and manually raising the vent, I took the micro switch assembly apart and wired around the micro switches so it would not happen again in the future. In my model there are two leads leading to the micro switches and one jumper that provides a common lead to both switches. To wire around them you simply need to run a jumper from one of the leads to the other lead completing the circuit and bypassing the switch. I removed all of the mechanical parts of the switch including the springs and plunger mechanisms and then reassembled switch housing and reassemble the rest of the fan housing etcetera. Everything works fine again and I no longer run the risk of at loose filter causing major disassembly work
Apr 16, 2013 | KitchenAid KIRD801HSS Kitchen Hood
Nokia c7 showing empty screen on start up
Your phone formate:-
Step by step.
1.Phone Keybord (Right Side 'Call')
2.Type: *#7370#
3.Then 'Yes'.
4.Restart your phone with solve your problem.
Feb 26, 2013 | Nokia C7 (8 GB) Smartphone
2008 Chevy Equinox would not start, turn key and nothing happened, replaced battery, ran just fine for a week. Tried to start one week later it acted like it wanted to start but wouldn't. Had ju
Usually a sign of something draining the battery.
The machine test probably showed the battery could hold a charge and the alternator was charging the battery.
You may need to have someone check for a power drain.
When the key switch is off, there may be a weak short to ground or a relay or component that is using power.
Jan 22, 2013 | 2008 Chevrolet Equinox
My hp 2180 printer will not print. When I click on print nothing happens. I have check everything nothing happens. The photocopier works only
Hi
Maybe the print spooler service had stop. Try to stop and restart it again. Try this solution.
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
If still not printer, try to set up or add once more the printer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 10, 2011 | HP Office Equipment & Supplies
Hi, few days ago I bought a Netgear NAS 2110 and connected it to my Netgear WNDR3700 router. I installed RAIDar utility and followed the instructions. Everything seemed to work alright. From my laptop I...
If it's new it's probably doing some housekeeping. The drives need to be formatted and then the RAID arrays need to be sorted.
On installing my server, it took days to complete, however, that was with existing data on the drive.
It might not be letting you switch off because it's busy and doing so would mess up what it's trying to perform.
If you don't want to wait to find out if all is OK, go into the configuratio utility and set just one drive up. This will show if it's working as a unit. If all is fine, install the remaining drives, maybe one at a time.
Dec 30, 2010 | NetGear ReadyNAS Duo RND2110 NAS server...
Electrical Help Please
nada. No gauges no lights absolutely nothing. All that happens is when I turn the ignition switch off the tach bounces backward quickly about 6 or 8 times. I put the bike on the battery tender and within 20 minutes it was showing in good shape. Still nothing. Checked battery leads. No problem. I checked all the fuses around the battery and up next to the dash. Nothing there. I R & R'd all of the relays next to the dash and the 3 behind the tool kit with the same relays off of my Mille. Still nothing. I changed the odd relay next to the battery that says UP on it. Don't know what it is but it rattles. Maybe a tip over sensor? Nothing. I tried jumping the bike off with a portable jump start battery. Nothing. I switched the battery out. Nothing. I pulled the front fairing and checked all connections. Found everything to be just fine. Put a battery charger on the fully charged battery and suddenly got ignition lights and headlights. Turned the key back off and once again nothing. A few more times it would come back and show lights and gauges but when I went to start everything went dead again. I'm thinking maybe the ignition switch? It doesn't seem worn out at all. I jiggled the key didn't seem to make a difference. The bike only has about 10k miles on it. Any ideas? ,Some 'friend'... did this ever happen to him? Good diag work so far, and I don't have anything specific to look at. Hopefully one of the sm-m-m-marter members can assist. ,,,
Nov 10, 2008 | 2004 Aprilia Tuono Racing
Tv troubleshooting
your keyboard is most likley bad..or tv  buttons/switch...
Oct 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shawn kemp skybox 1995 hoops power Logo
60 people viewed this question
Top Fleer Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Fleer Vehicle Part and Accessory Expert? Answer questions, earn points and help others
