Question about Singer Tiny Tailor TT700
Throat plate - Singer Tiny Tailor TT700
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
I'm afraid you'll have to be more specific; I have no idea what problem you're actually having.
Posted on Jan 22, 2014
Phaff throat plate 98-694826-00
hi beth.
not sure what you are asking,but try this link out.
Pfaff throat plate 98 694826 00 Google Search
Nov 03, 2017 | Sewing Machines
Can I buy only the clip portion of the throat plates? One clip on each of two of my throat plates have broken. The plates are good and I only need the little clips.
try a sewing machine service shop ( any one ) and see if the parts are available or if they have spares from other machines
Oct 14, 2015 | Sewing Machines
How to replace the throat plate spring
This can be tricky. At a 45 degree angle push the top spring under the holding area of the machine. Hold this spring firm and push down on the second spring. Rotate the throat plate simultaneously until the plate is in its correct position.
Aug 13, 2015 | Sewing Machines
My needle is hitting the plate when I try to make a buttonhole
Sue: According to http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCAQFjAA&url=http%3A%2F%2Fwww.consew.com%2FFiles%2F112347%2FInstructionManuals%2FCN2230R.pdf&ei=ZGtVVaa7OYKRyQTGo4GoBA&usg=AFQjCNG-1xhxBFtfhJZJn7y5QZ_0E1r48w&bvm=bv.93564037,d.aWw : "The Throat Plate is not held firmly in place. Its screws are not tightened securely. The Throat Plate shifts around and is being hit by the Needle. Solution: Locate the Throat Plate correctly and tighten firmly the throat plate screws."
May 14, 2015 | Sewing Machines
I took the throat plate off to clean my Imagine serger. When I try to put bak on it has to be pushed back down and is against a small piece, seems to be too close.
THROAT PLATES ARE HELD ON EACH SIDE WITH A SMALL PIECE OF METAL (SPRING). 1. PLACE THE PLATE AT AN ANGLE OF THE THROAT. 2. AT THE SAME TIME CAREFULLY PUSH EACH SPRING UNDER THE PLATE. 3. SLIDE THE PLATE TOWARDS THE AREA WHERE THE PLATE SHOULD FALL INTO THE LOWER POSITION.
Feb 26, 2015 | Baby Lock Imagine
Please help my throat plate[needle plate] is banging loudly..the faster I sew the louder it knocks[throat plate against its base]..it's as if its too loose but see nowhere to tighten or screw it in...
I would like to help you but I do not know what model your machine is. Please answer this and I will try to help you. Knocking is usually lint built up under the throat plate and has to be removed to get it cleaned out.
Apr 18, 2011 | Singer Sewing Machines
Removing needle plate from viking sewing machine
throat plate is usually tight with screws may be that the holding magnet and once the button is located near shuttle and it should press plate up...
Dec 24, 2009 | Husqvarna Viking 1
The fabric does not feed properly.
Remove the throat plate and clean out the lint in between the feed dogs (teeth). Make sure the throat plate is not bent downwards where the needle goes through. Also, after removing the lint turn the machine over by hand, the feed dogs at their highest point should be about 2mm above the throat plate.
Also, try this link, there are many free books.
http://www.singermachines.co.uk/Parts_&_Ser/indstbooks.htm
Jul 06, 2009 | Singer 3116 Simple
The needle hits the throat plate
if a new needle still wont align with the needle plate, your needle bar is out of whack
Mar 18, 2009 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
