Question about Wolfgang Puck BTOBR0040 Toaster Oven with Convection Cooking
Kitchenaid KCO222 oven no hot
Led ok, timer ok, burner resistor ok,
Timer knob won't hold. May be sprung. Is it fixable
I have the same problem. The part of the knob that attaches to the oven has split. I have repaired it with epoxy and will update this question if it works. I also searched KitchenAid for a new knob and they do not have one. I did locate a knob (part # AP3885089) from AppliancePartsPros.com and have ordered it. It is listed as a Whirlpool part but looks like the KitchenAid. I will update you as to the epoxy repair and the suitability of the AP38 when it arrives. Hope this was of assistance.
Sep 15, 2015 | KitchenAid Kc010050b-1 Stainless Steel...
The toast part works but the bake and broil does not work , the blue light does not come on and no heat is produced
We've got the same problem and I just took ours apart.
Bad news: I'm pretty sure it's the circuit board. It's not the timer knob, and I'm almost positive it's not the upper selector knob. Most of the components on the circuit board are only used for the "bake" mode to regulate temperature. The board is marked, "128301 Timer PCB". I looked into whether one can buy a replacement board from Kitchenaid, but it's not on their parts list. If I had to guess, I'd say it's the relay on the board, but it's only a guess. Shoddy components, plus it gets hot in there and "bakes" the board. The little fan in the side isn't part of the "convection." It's for cooling off the circuit board. Don't laugh.
Even worse, next to the thermostat on ours, there's a little rubber insulator that's burnt to a crisp. The connection under this insulator was also loose. It hasn't affected functionality, but it doesn't instill confidence in the design. Kind of scary. Unplug this unit when not in use!
Only a one year warranty. I think we now have an expensive toaster.
Jul 24, 2011 | KitchenAid KCO1005OB 1400 Watts Toaster...
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Sep 30, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Where do i find a replacement knob for timer on the kitchenaid toaster oven model # kc010058
I contacted kitchenaid at 1-800-541-6390 and they graciously sent me a new one at no cost.
Dec 01, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
On/off timer button broken, just spins, kids may have twisted wrong way
It would help us to answer your free question here if you include a make and model #..
Also - your question looks a bit like a statement.. Please ask your question clearly..
Are you looking for a replacement timer button ?
Thank you..
Sep 23, 2009 | KitchenAid Toaster Ovens
Kitchenaid kco1005 toaster oven broken timer dial/knob
My kitchen aid toaster oven when set on baking the light is not coming on.
Aug 20, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
I bought a refurbished kitchenaid countertop toaster oven for a super great price and it works like a dream. The only problem is the broken timer knob. I've searched on the internet and I can't find a...
I would suggest calling Kitchenaid Customer Service. They would be able to replace that broken timer knob for you at no cost.
Their toll-free telephone number is 1-800-541-6390.
May 10, 2009 | KitchenAid Toaster Ovens
TIMER KNOB IS BROKEN
I've had the same problem. I checked out the Kitchen Aid website, called the toll-free number listed on the site (800-541-6390), and talked to a very pleasant and helpful customer service representative. She said she would be sending a free replacement knob that would arrive in 7 to 10 days. It may sound ominous, but if ya can't fix ya, ya gotta replaceya!
Dec 03, 2008 | KitchenAid KCO1005OB 1400 Watts Toaster...
Wolfgang Puck BTOBR0040 Toaster Oven with Convection Cooking Logo
35 people viewed this question
Top Wolfgang Puck Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Wolfgang Puck Toaster Oven Expert? Answer questions, earn points and help others
