Question about Heavy Machinery
Hyster 15.5 lift/L.P.G.fuel/doesn't run when given gas
Starts fine and idles fine when given fuel it deies out no power
    Problem Solver:
  • 28 Answers
IS YOUR GAS COUPLING FITTED CORRECTLY? (THEY HAVE A HABIT OF CROSSING THEIR THREADS AND DON'T OPEN THE VALVE ON THE BOTTLE), IS THE GAS BOTTLE EMPTY OR ITS VALVE FAULTY? (CHANGE THE BOTTLE), IS YOUR GAS FILTER CHOKED?, CHECK ALL OF YOUR VACUM HOSE'S AROUND THE INLET MANIFOLD, CARB AND GAS REGULATOR. IF NONE OF THESE WORK THEN CONTACT ME BACK WITH AS MUCH INFO AS POSSIBLE (GOOD LUCK)
Posted on Jan 05, 2014
85 s15 hesitates/sputters
check for a faulty / blocked accelerator pump /circuit as this fits the lack of fuel squirt on acceleration description. Also check the timing of the ignition.
Jan 23, 2014 | 1985 GMC S-15
CBR 600F cuts out when given throttle
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike idling with choke on dies when applying throttle CBR Forum Enthusiast...
cbr600f cutting out
Honda CBF600SA Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Oct 14, 2017 | 1989 Honda CBR 600 F Hurricane
Mower carburator trouble i think
Soooo...You haven't said what the problem is. What "result" is the same?? Is it stalling or is it just not running at full power? If it starts fine and idles fine but then stalls or doesn't have power when you juice it, it sounds like a fuel problem. It is unlikely a carb issue if it gets regular use and as long as its not sitting for long periods of time. I would first check the fuel filter. If that's fine, then I would check the vent hole on the gas cap (if you have one). If it is a gravity-fed fuel system and the vent hole on the gas cap is clogged with dirt, dust, and debris, then the gas will not flow to the carb fast enough and you'll get a very lean mixture. Sure, it will idle fine because the engine isn't demanding much fuel at idle, but when you open up the throttle it will stall because the air:fuel ratio will be too high (symptomatic of a lean mixture) Last thought: Dirty air filter Hope this helps
Jul 28, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Keeps stalling out
If it starts fine and idles fine but then stalls or doesn't have power when you juice it, it sounds like a fuel problem. It is unlikely a carb issue if it gets regular use and as long as its not sitting for long periods of time. I would first check the fuel filter. If that's fine, then I would check the vent hole on the gas cap (if you have one). If it is a gravity-fed fuel system and the vent hole on the gas cap is clogged with dirt, dust, and debris, then the gas will not flow to the carb fast enough and you'll get a very lean mixture. Sure, it will idle fine because the engine isn't demanding much fuel at idle, but when you open up the throttle it will stall because the air:fuel ratio will be too high (symptomatic of a lean mixture) Last thought: Dirty air filter Let me know if this helps
Jul 27, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Can't get gas to 22hp Kohler. I have check the filter, lines and the fuel pump. Tank is half full and when the engine spins over, no gas. HELP ME PLEASE!!!!!!!!!!
If it starts fine and idles fine but then stalls or doesn't have power when you juice it, it sounds like a fuel problem. It is unlikely a carb issue if it gets regular use and as long as its not sitting for long periods of time. Check the vent hole on the gas cap (if you have one). If it is a gravity-fed fuel system and the vent hole on the gas cap is clogged with dirt, dust, and debris, then the gas will not flow to the carb fast enough and you'll get a very lean mixture. This is because the engine exhaust cycle creates a vacuum which siphons fuel from the gas tank to the carbs- and if the vent hole is clogged the fuel wont flow. Sure, it will idle fine because the engine isn't demanding much fuel at idle, but when you open up the throttle it will stall because the air:fuel ratio will be too high (symptomatic of a lean mixture) Clear out the vent hole in the gas cap and see if t Hope this helps
Jul 27, 2012 | Garden
Ford 460 loses power then dies. Starts back up. Idles fine.
It sounds like you might have a clogged catalatic converter on the exhaust system.
Apr 23, 2010 | 1999 Ford Super Duty F 450
96 jeep grand cherokee starts but wont idle
CHECK FUEL REGULATOR ON FUEL INJECTOR RAIL,&ALSO FUEL PUMP, CHARLIE
Feb 21, 2010 | 1996 Jeep Grand Cherokee
Heavy Machinery Logo
541 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
