Question about JayBird Gear LLC BlueBuds X
Connection unsuccessful but in range
The wireless earphones ran out of battery, then I charge it over night tried to re connect this morning then it would'nt work. Please help
Ran out of gas this morning, filled tank, killed battery trying to start it, jumped it, ran fine for 4 miles then started cutting out, now it won't turn over at all,... Ant suggestions
Hi Mike:
Since you've solved the gas problem, it looks like you're just dealing with a bad battery.
Try getting a jump with boosters to get it home.
Then check the battery......... fluid level....... Will it take a charge...... Will it hold a charge.
are the terminals and connections all good?
All the fun stuff.
Enjoy
Jul 16, 2015 | Cars & Trucks
Boot up
check for power from your charger or the connection going into your unit did the battery read fully charged could be a battery issue
Sep 04, 2012 | Wintec Industries FileMate Light 7...
My phone ran out of battery this morning and couldnt get to charge it untill later this night and when i plugged it into my computer the charge light is on but then screen isnt. Generally when i do this...
Seems like your phone ran totally ran out of battery, that is not a big deal you just need to recharge it for a longer time then usually you do. Hope that will solve your problem.
Thank you!
Jun 30, 2010 | Cell Phones
Phone ran out of battery last night and this morning when im trying to charge it the jg logo is just flashing sos
This maybe because you have run the battery down.
Plug it in and give it time to get enough charge and hopefully it will find a signal.
Nov 08, 2009 | LG Secret ? KF750 Cellular Phone
My charger is not working since morning. it was well and good last night.
What do u mean it's not working...??
Check for any loose connections...
It's a laptop charger, and u said it was workin' fine last night, then there's bound to be a loose connection......
If nothing else [like thunderstorms, voltage fluctuations, or any other harmful incidents] hasn't occured, it's connection prob....
Try using different plug-points.... Try checking the adapter if it's correctly connected or not...... If none of this works, call a comp spec.....!!
Jul 08, 2009 | Computers & Internet
Charged my phone last night and will not turn on this morning
Thats what my phone does when the battery is dead. perhaps it did not charge last night. see if the phone will turn on while connected to the charger. if so, the battery is dead or defective.
Feb 27, 2009 | LG VX5200 Cellular Phone
Laptop compaq presario f500,running vista.Wireless is not working,Windows cannot load the drivers required for this device. (Code 31)
Matt Sydney Aug 4, 2008 00:28:44 GMT 10 pts
I experienced this problem last night, and seemed to have fixed it this morning.
SYMPTOMS: HP Pavilion dv9000, Win Vista x64 Ultimate. Running on battery, battery level became critical; windows went into 'Hibernate' mode. Upon plugging in to mains power, and resuming the Windows session, the Wireless is still disabled, no matter what position the switch is in.
POSSIBLE CAUSE: Critical battery switches off the wireless network card to preserve power. Motherboard seems to log this status but when re-connecting to mains power the card does not receive power again. Uninstalling the driver and getting Windows to re-install automatically upon re-boot does not work.
SOLUTION: Charge up the battery whilst the computer is running. You can charge it to a substantial level, say, above 25%. Disconnect mains power so that your laptop is running on battery only. Set your wireless switch to OFF (this is usually to the left position, away from the orange indicator). Now run your computer down to the critical battery level again (perhaps overnight). In the morning when you press the power button, the 'CHARGE' indicator (looks like a lightning bolt) on the front of the laptop should flash quickly, indicating that there is no charge in the battery. Remove the battery from the laptop's underside. Wait a couple of seconds, then press and hold the power button for 30 seconds. Keeping the battery off the laptop, reconnect mains power. Boot up your PC. When at the Windows desktop and all your startup programs have finished loading, switch your wireless on (to the right position). You should now have a blue light, and wireless should once again be working. You can now re-insert your battery. You might have to setup your wireless network connection again as mine seemed to be 'lost', but at least hopefully the main problem is now fixed.
Jamie Madriz Aug 8, 2008 01:58:15 GMT N/A: Question Author
Matt, i did what u said, and i'm happy because my wireless switch is WORKING! :) Hopefully it stays this way.
Sep 23, 2008 | Computers & Internet
JayBird Gear LLC BlueBuds X Logo
42 people viewed this question
Top JayBird Gear LLC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JayBird Gear LLC Audio Player and Recorder Expert? Answer questions, earn points and help others
