I Need a Wiring schematic for a Payne air handler, Model #PF1MNA036
4 Suggested Answers
  • 20 Answers
SOURCE: Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Posted on Jul 23, 2008
  • 232 Answers
SOURCE: wiring diagram for model # GB5BM-T49K-C nordyne
http://www.nordyne.com/literature/246d.pdf
and if you wouldnt mind giving me positive feedback. Thanks
Posted on Sep 17, 2009
  • 146 Answers
SOURCE: need wiring schematic for intertherm model
schematics start around page 20 hope this helps you
mike
Posted on Jun 05, 2010
How to remove Heat strips from intertherm furnace to make an air handler? Wiring schematics
WHAT??? Removing heat strips does not make an air handler. Air handlers have heat strips, please explain
Jun 17, 2017 | Intertherm Heating & Cooling
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
Payne air handler with possible GE X13 Failure
Check your dip switch settings on tonnage and your CFM per ton settings. Also make sure they wired the the low voltage for cooling to Y and not YLO if its a single stage compressor system.
Sep 23, 2012 | GE Carrier Bryant Payne 1/2 Hp 115 230v...
Modle No. pa10ja042oooacaa I need a wiring schematic for this unit . this is a split system the thermostat wires and the sequence and the relay need rewiring.
this is a 10 seer straight cool unit only 2 wires going to the unit install a new contactor and the thermostat wires go to the contactor unless u are talking about the air handler this is not the model # for the inside unit
Aug 30, 2010 | Heating & Cooling
There is no schematic or number on air handler .outside unit is Goodman # CPE48-1FB.How can i get a schematic for Air handler.
I need more info than just the outdoor unit number. The air handler will be a specific number. If you pull the access panel off the heater, there will be a faceplate inside with the unit name and model number as well as a schematic on the back side of the door.
May 12, 2010 | Goodman CKL60AR60 Air Conditioner
Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Jul 03, 2008 | Ruud UBHC Air Conditioner
TempStar 10 AC
visit www.gotempstar.com for the schematic on this unit. Coincidentally, your air handler unit should not draw 15.6 amps with an additional 40 for the heater.
Jan 07, 2008 | Dishwashers
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
