Question about KitchenAid KBRP20EMSS Bottom Freezer Refrigerator
Loud noise, not ice maker
Our 19 year old kitchenaid krbs21k refrigerator makes a very loud noise, maybe a fan or motor? It's not constant but does run a lot, loudly. The ice maker hasn't been working for a long time and we don't use it. This is a relatively new noise. Otherwise it still works very well.
  • KitchenAid Master
  • 17,328 Answers
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Posted on Dec 30, 2013
5 Suggested Answers
SOURCE: 12 year ol KitchenAid Superba 42 making a loud rumbling noise intermittantly.
Put a screwdriver on the compressor with the handle on your ear and listen. If you hear the loud grumbling noise from the compressor you're probably better off replacing the fridge.
Do the same with the fan motor. If it's the fan motor, you can easily replace that.
Posted on Mar 17, 2008
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
fixyourboard
  • 310 Answers
SOURCE: My Kitchenaide Superba Refrigerator sounds like
Check that the condenser isn't clogged up with pet fur and dust. That will cause your symptom.
Posted on Jun 26, 2010
  • 1891 Answers
SOURCE: My frigerator is making a very loud noise coming
the noise is the evap fan hitting . now either its comming off the motor shaft or its hitting ice build up caused by incomplete defrost . It's time to call the repair man . as the noise will quit and the cold will too . mm
Posted on Jul 06, 2010
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
My frigerator is making a very loud noise coming from the ice maker area. It sound like a airplaine engine getting ready to take off. Sometimes it gets louder and louder. If I turn the switch to off then...
Jul 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Our refrigerator just suddenly started to make this loud grinding sound..it appears to be coming from the freezer side. I turned off the ice make and reduced the freezer temperature but it still keeps...
This could be a failure of the evaporator fan. Also maybe some ice has formed from water dripping from the ice maker and had now produced an icicle which could be hitting the fan blade of the evaporator motor. Remove back cover to the freezer/fan and check the fan operation while it is running.
Mar 29, 2010 | KitchenAid Refrigerators
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Servis frost free fridge /freezer
not sure if it happens with this brand but I know others have a problem with ice build up that can interfere with the fan. If you can remove the back panel in the freezer section and take a look. If not try defrosting it for a couple of hours to see if it makes a difference.
Sgt 48
Jun 07, 2008 | KitchenAid KTRS22EM Top Freezer...
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
GE profile side by side refrigerator
In this Video Im Replacing Evaporator Fan Motor.
Sep 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
KitchenAid KBRP20EMSS Bottom Freezer Refrigerator Logo
315 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
