HST1149PO11 wire on GE washerWLRR5000GOWW
Washer does not was or spin,could this wire and fuse be the problem and can i bypass with another wire?
5 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: My GE washer won't spin or agitate
check the motor capacitor if your motor doesn't turn when powered, otherwise the "wig-wag"coil could be faulty,these coils shift your transmission for different cycles
Posted on Aug 24, 2009
  • 714 Answers
SOURCE: I have a GE washer (WBB4500G2WW) - about 18 months
have you checked the motor coupling?
Posted on Feb 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: GE washer model# GNSR3150H0WW won,t start
It appears your motor or motor controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
SOURCE: GE Profile WPRE6100G Top Load Washer how do you
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Posted on Dec 26, 2010
Can i bypass the magnetic safety switch on my Ge washer? Model 175D2750G309 top load.
Connect the wires going to the sensor to each other to affect bypass.
Dec 15, 2016 | GE WBSR3140DW Top Load Washer
Washer fills and gives two beeps, then nothing. It wont spin at all but the coil shows 60 ohm resistance.
G E washers. I usually end up replacing the motor with the model shifter the alignment shouldn't affect Anything look at the board on top of motor for a led lite 1 steady flash is normal if none check right side of harness I think it's a white wire with red stripe for a hidden fuse bypass it with a jumper wire give that a shot ge stopped using fuse
Apr 25, 2016 | Washing Machines
I have a GE washer model WHRE5550K2WW. we had a power surger which stopped the wash completely. I replaced the curcuit board behind the control switch witch the allowed the machine to fill,but would not...
Built into the wire harness from the machine control to the inverter board for the motor is a fuse..saddly the only way to replace the fuse is replace the wire harness
GENE
Sep 08, 2011 | GE WHRE5550K Top Load Washer
GE Profile WPRE6100G Top Load Washer how do you bypass lid safety switch? Unit pumps but won't spin.
Dec 19, 2010 | GE Profile WPRE6100G Top Load Washer
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Aug 23, 2009 | GE Profile WPSR3100W
GE Profile wont spin,why?
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wiring to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you replace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Thanks for using Fix-ya. A high rating would be appreciated for your free question :)
Jul 26, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
