Question about Intertherm P3RC-030K Air Conditioner
I need a wiring digrahm for a payne air handler model # PF1MNA036
2 Suggested Answers
  • 146 Answers
SOURCE: need wiring schematic for intertherm model
schematics start around page 20 hope this helps you
mike
Posted on Jun 05, 2010
I have a payne airhandler blower motor want come on blower model 5sme390x
Many air handlers have a safety switch on the filter access cover panel, our on the electric control panel. The switch may not be making contact, try moving the cover to try making the south work, or remove the cover and verify there is a switch, a button switch and operate it by hand with the a.c. on, user caution with rotating parts.
Nov 02, 2015 | Heating & Cooling
I bought a new thermostat that requires a C wire. I have a spare wire in the cable that goes from my thermostat to my air handler. It's a Model B3BM-O36K-B Frigidaire model air handler.
At your AHU there may be a terminal block that has a C terminal. If not, you will need to locate C. Your outdoor units control wire should have 1 that connects to the Y signal allowing 24v to pass from Y at the t-stat to a wirenut at the air handler, from that wirenut to the contactor. And C comes from the contactor to a wirenut at the airhandler and to C side of transformer. Common wire colors from o.d.unit are red=24v and White from the o.d. unit, (NOT THE WHITE FROM T-STAT!) is the common. The transformer may also have a tag/sticker that states 24v and common with a color of wire for C. And if the t-stat takes batteries that you need to install, you shouldn't need C wired in. C is there so you don't need batteries, if it has a battery option.
Jun 22, 2015 | Frigidaire Heating & Cooling
I have a Payne Rooftop Gas Heater that had a bad thermostat, and when I replaced the thermostat I believe that I shorted a wire and blew the low voltage fuse on the 24v system when I had the wires hoo
Go to the air handler and look near the transformer for a 3 amp blown fuse. Pull it out and put a new one in (it resembles a fuse used in cars).
Dec 09, 2013 | Heating & Cooling
Berrow fan doesnot stop running after ac shout down
It is snubber problem. It causes due to emf field in fan motor. You have to just add a snuuber component in pcb or problem can be removed by switching mains off
Oct 14, 2013 | Carrier Bryant Payne Air Handler Control...
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
Payne air handler with possible GE X13 Failure
Check your dip switch settings on tonnage and your CFM per ton settings. Also make sure they wired the the low voltage for cooling to Y and not YLO if its a single stage compressor system.
Sep 23, 2012 | GE Carrier Bryant Payne 1/2 Hp 115 230v...
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
Need wiring digrahm for 5hp buffalo tools air compressor
I have a 5.5 hp kobalt air compressor, I removed the cover where the capacitors are to replace the overload reset button, I want to make I wire them right, can you help me??? by the way, get me information how to wire the capacitors back. Thanks lui
Apr 01, 2009 | Air Tools & Compressors
Townhouse ac/heater combo won't start
I am not familiar with this air handler, but I haven't found too many with fuses. You just blow the transformer... but if you found a place that says there is a fuse, maybe there is.
If you can use a volt meter, check the voltage between the red and blue wire in the thermostat. It should be 24 volts AC. If it is there, your problem is something else... Some might suggest you use a short jumper wire from the red to the green and see if the fan comes on to check your 24 volts if you don't have a meter, but I would never suggest that...
If you determine that the 24 volts is not there then you should find that transformer in the air handler and follow the leads out and see if they lead to the fuse, if it exists. You might consider that the transformer is bad if you can't find a fuse. If able, check the primary for your supply voltage, 115 or 230 volts AC, and the secondary, 24 volts AC.
If your lucky, someone that is familiar with this model will answer with all the locations, etc...
Always be careful when working with electricity. If you decide to get into the air handler to troubleshoot your transformer, turn off the breaker while exploring and only turn it back on when you are ready to make voltage measurements and are confident that you know what you are doing.
Jul 17, 2017 | Heating & Cooling
Intertherm P3RC-030K Air Conditioner Logo
37 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
