Question about Philips 37PF9631D 37 in. LCD HDTV
Phillips tv red blinking - Philips 37PF9631D 37 in. LCD HDTV
  • 3 Answers
SOURCE: phillip tv
Probably bad inverter board. It has a short in inverter board and as soon as it powers up it detects the excessive current draw and shuts the set back off. Open it up, unplug the power supply connections to the inverter board then try to turn it on, if you get a green light then the inverter is bad. Try E-bay for replacement board.
Posted on Dec 13, 2008
  • 35 Answers
SOURCE: phillips plasma tv blinks a red light
Could be bad capacitors on PSB. Email me if your still interested in DIY. SW upgrade won't help you if you cannot turn the tv on.... YOur set went into protection at startup. Could be caps could be boards gysgt2u1@yahoo I'll try to help you while I search for a solution to mine....
Semper Fi
Posted on Mar 02, 2009
D_LLAMA
  • 6 Answers
SOURCE: 42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
  • 187 Answers
SOURCE: Blinking red light on phillips plasma tv
The mainboard is damaged.
Posted on Jul 04, 2009
maatmartin7
  • 1229 Answers
SOURCE: Phillips TV Model: 52PFL7422D/37 Purshased
First place to check is the power supply board. I have not repaired this particular model. I'm very certain you have two bad capacitors in the power supply. This is a classic problem for Philips flat TVs. The capacitors will be bulged or skinned. Be sure to replace them with same values. I would certainly gamble my time removing the power supply for inspection. Spending a few bucks on two capacitors may prove good. A working TV is near. Thanks for asking and show all hands of support!
Posted on Jun 30, 2011
Phillips TV Model: 52PFL7422D/37 Purshased this TV Dec 16, 2007. No I have blank screen with the TV blinking a read light at the left - the red light flickers - blink, blink,blink,blink,blink then 3...
Jun 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Tv wont turn on it cycles through about 5 times then it turns off blinking 2 red lights at the bottom of the monitor.
Are you sure its two red lights blinking and not the one red light blinking and you can see it through the other window to look like two red lights? If so sounds like your lamp is blown. Open the back door and unscrew the lamp (2 phillips screws) and check to see if your lamp is blown.
Nov 02, 2010 | Toshiba 50HM67 50" HDTV
I have purchased a insonic tv master remote and it didnt have any instructions with it. I need to program it to my phillips tv
press tv. then press the red and select at the same time light will blink twice enter 0081 if tv turn off press select then tv! if it don,t turn off press tv then select and red together light blinks twice! now press power on and off switch until tv turns off when it turns off press select to store code
Sep 13, 2010 | Televison & Video
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Phillips Plasma 42" TV
what model do you have?
Jun 23, 2008 | Televison & Video
Need code for phillips remote
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 09, 2008 | Philips Televison & Video
Phillip tv
Apr 16, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Philips 37PF9631D 37 in. LCD HDTV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
