Question about Siemens Computers & Internet
"CONNECTED to DSI_IP!" - Siemens Computers & Internet
ERROR CODE FOR DSI 052010-1
Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings; manually assign an IP address to the Nintendo DS.
Don't know how to find your router's security key?
Manually assign an IP address to your Nintendo DS.
For more help visit cbrtechsolutions
Jul 01, 2012 | Nintendo DSi Black Console
I need internet on my dsi
Well, have you done the homework?
1. DSI needs WiFi, ie, wireless internet. Do you have a wireless router or wireless modem router in your place?
2. If yes, have you enabled the wireless radio in the router. This can be done by opening up the router options by typing the IP Address of the router (it should be somewhere written in the router itself) and login. If you don't know the password, google your model number and you will get all information like default ip address, login etc. If possible download the manual from the manufacturer website and go through it to familiarize the options. (If you have an apple router, you will need "airport utility"..google).
3. Once logged in as "admin", look for "wireless" options (Manual will help you), enable "radio", "ssid", note down the ssid name, and for troubleshooting purposes, leave the security "off/disabled". Save/apply changes.
4. Make sure wireless "G" is selected or a mode thats compatible with wireless "G" (go through the options, mostly default option will suffice). If this is in another page, again, save or apply changes.
5. Reboot the router, wait for a couple of minutes till the lights for internet and wireless appears.
6. From DSI, search for available networks, find the ssid name that you have noted down and click connect.
7. Hopefully, it should connect, otherwise, you may have to manually enter DSI IP Adress, subnet mask (255.255.255.0), gateway and dns servers (both router IP Adress). If your router address is, say 192.168.1.1, then give dsi an ip adress 192.168.1.xx where xx is a number between 2 and 255. That is, what ever ur router ip address is, just change the last digits to anything under 255, excluding the router address. Now try again, hopefully everything should be settled.
8. Look into DSI manual to see whether it supports wpa/wpa2 security or just WEP. You may also have to take into consideration any other devices that connect to router wirelessy, like laptops, smart phones, tablets etc. If all of them supports wpa/wpa2, go back to router options and select that security, create password, write it down. Otherwise select "WEP" encrryption. (The point to remember here is the lowest common denominator, ie, if DSI supports only WEP, selecting WPA/WPA2 will be useless, as DSI will not connect, even if it sees the SSID.
9. Save changes, reboot router, wait for lights to steady.
10. From DSI, again select your SSID name from available networks (just to make things easier, shut down DSI, restart to disconnect earlier connections), it will ask for password or both password and security type. If DSi supports WPA/WPA2, and ur security is set as such, and DSI is not connecting, play with the options, if any, like "WPA only", WPA2 only" WPA/WPA2" and try to connect.
You should succeed with this much details. Good luck
Jan 15, 2012 | Nintendo DSi Matte Blue Console
What is an ipaddress
hi an ip adress is the numeric adress that your Internet Service Provider gives you that your modem holds in memory. to find yours go to google and type in "MY IP ADRESS"
Feb 11, 2011 | Nintendo DSi XL Burgundy
How can i obtain my ip address
On the DSi's main menu, you should be able to scroll to an option that contains the settings. One of the buttons on this page will allow you to see information about your DSi, including the MAC/IP address (but unless the IP is static, youll be set to DHCP.)
1. From the Nintendo DSi Menu, select System Settings.
2. Scroll over to page 3 of the System Settings.
3. Select Internet.
4. Select System Information.
The IP Address should be on the screen that appears.
Dec 20, 2010 | Nintendo DSi Blue Console
No internet dsi
nintendo .com tipe in that exact err code.tttttttttttttttttttaaaaaaaaaaaaaaaaddddddddddddddddaaaaaaaaaaaaaaaa
Mar 07, 2010 | Nintendo DSi Black Console
I have a black dsi and have duplicate ip addresses i can not connect to the internet
Enter a manual ip that does not conflict with any other device connected to your network.
Jan 17, 2010 | Nintendo DSi Black Console
DSi says that duplicate IP addresses exist and to check my DHCP settings
I got this same error using a Linksys WRT54GS.
On the basic setup page, under Network Setup>Network Address
Capture(lefemenu.dhcpserverset)Server Settings (DHCP), I changed the Starting IP Address from 192.168.1.100 to 192.168.1.110 and amazingly it worked.
Jul 27, 2009 | Nintendo DSi Blue Console
Computers & Internet Logo
120 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
