Question about Apple MD440LL/A iPhone 4 8GB CDMA Verizon - White
Remove sim card tray carefully
Cant find sim card slot
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 10 Answers
Its there left of side of the phone its look lik a tin hole sww\\ee and put a pin there it ill be open
Posted on Dec 31, 2013
How I get the sim card out of my iPhone without damaging it?
You have to be careful. You can try using something like a paperclip but the best way is to use an iPhone Sim Card Tray removal tool. Here's anarticle with some basic instructions to help you.
http://www.gazelle.com/iphone/sim-card-removal
Jul 17, 2012 | Apple Sim Card Tray Removal Tool
How to insert sim card in iphone 3g
Turn off your iPhone 3G and make sure any cords or connector cables are removed from the device. Then, hold your iPhone 3G upright.
  • Locate the Sleep/Wake button and headphone jack on the very top of the iPhone. Between these two components you will see a very small hole.
  • Insert the tip of a paper clip into the hole to release the iPhone's SIM card tray. The small tray will pop up relatively quickly from the top of the iPhone. If there is already a SIM card in the tray, use your fingers to remove it.
  • Insert the SIM card you want to install into the phone facedown in the tray. Make sure the side without the reflecting panel is inserted first.
  • Press the SIM card tray gently back into the slot until you hear it "click" into place. Now turn your iPhone on. All of the information on the card will now be in your iPhone 3G.
  • Mar 16, 2011 | Apple Computers & Internet
    I cant make phone calls it says no sim card. I have a Iphone 3gs
    You iPhone simcard may just have been jostled loose. The sim card sits in a tray, accessible using a paper clip. Try removing it and replacing it, that may help.
    Mar 13, 2011 | Apple iPhone 3GS Black (16 GB)
    How to remove sim card?
    For removing the SIM Card, insert the end of the 'SIM eject tool' (supplied in the box) into the hole on the SIM tray. Press firmly and push it straight in until the SIM tray pops out. If you don't have a SIM eject tool, you can use the end of a pin/paper clip. Pull out the SIM tray and remove the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
    With the tray aligned as shown, carefully replace the SIM tray containing the SIM card
    in iPhone.
    Oct 07, 2010 | Apple iPhone (16 GB) Smartphone
    I can't set up my SIM Card on my iphone. How do I do it?
    1 Insert the end of the ''SIM eject tool'' (supplied by apple in the box) into the hole on the SIM tray.
    Press firmly and push it straight in until the tray pops out. If you don't have a SIM eject
    2 Pull out the SIM tray and place the SIM card in the tray.
    3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card
    in iPhone. Similar course of action may be done for removing the SIM card.
    Oct 05, 2010 | Apple iPhone Smartphone
    Ii got a unlocked iphone had signal for the first hur or too now has none even tho it says orange has no bars and cant txt or call or recive
    Reset the iPhone:
    It has been observed that simply resetting the iPhone can resolve signal strength issues.
    Reset network settings:
    In some cases resetting the network settings has also helped so tap Settings, tap General, tap Reset, tap Reset Network Settings.
    This will restart your iPhone and will also delete any stored Wi-Fi passwords as well as DNS settings and more.
    Place your SIM card again:
    If your iPhone’s SIM card is not placed properly, it has been observed that it can affect signal strength.
    So a good idea would be to remove your iPhone's SIM card by pushing a straightened paper clip into the small hole on the top of the device to open the SIM tray, then check for debris inside the tray or SIM card slot, remove it by blowing into the slot or using compressed air and then placing the SIM card properly and then re-inserting the SIM tray.
    The notion is that improper SIM contact can result in a weak signal, so the above procedure could help.
    Attaching scotch tape to the SIM card:
    This is indeed the most ingenious methods, it appears that attaching a small piece of scotch tape to the outer side of the iPhone’s SIM card (the side of the SIM card that does not have metal contacts) can result in a surprising boost again borrowing from the notion that improper SIM contact can result in a weak signal.
    Jun 02, 2010 | Apple iPhone 3G Black Smartphone
    Sim card location on apple iphone 3g
    On the top of your device you will find the SIM tray. There, you'll see a little hole. If you have the SIM eject tool, insert its end firmly into the hole, until the SIM tray pops up (a paper clip would also do the trick, instead of the SIM eject tool). Remove the SIM tray, place your SIM card into it (aligning the angled corner), and carefully place the SIM tray (along with the SIM card) back to its place.
    Hope it works for you.
    Cheers! Carlos
    May 11, 2010 | Apple iPhone 3G
    How to put sim card to the iphone?
    SIM card slot is in top of iPhone. From iPhone Manual:
    If your SIM card was not preinstalled, you must install the SIM card before you can use iPhone.
    Install the SIM card:
    1 Insert the end of the SIM eject tool into the hole on the SIM tray.
    Press firmly and push it straight in until the tray pops out. If you don’t have a SIM eject tool, you can use the end of a paper clip.
    2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
    3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
    Aug 11, 2009 | Apple iPhone Smartphone
    My treo 680 is saying it cant read the sim card, but its brand new
    You might try cleaning the contacts with some fine 400 grit sandpaper or other contact cleaner. I have a 2 year old 680, and I cut a piece of this sandpaper to the same size as the sim card. I pushed it into the slot, and ran it in and out for half a minute. I also sanded the contacts on the sim. Not too much, mind you, but it cured my problem. Good luck...
    Jul 29, 2009 | Palm Treo 680 Smartphone
    Sidekick 2
    Sorry, the sidekick II doesn't have a battery that can be pulled out. You need to pull back the bumper on one side to access the sim card slot.
    1. Follow these instructions to remove your operator-supplied SIM card from your device:
    2. Turn off your device by pressing the power on/off key.
    • Expose the SIM card slot by peeling back the bumper from the top-left edge of the device: t02005-2.jpg
    • Press down on the silver "catch" and the SIM card will spring out of its slot. Remove the SIM card carefully. (Always handle your SIM card carefully since the card and gold contacts can be easily damaged by scratches or bends. Be sure to keep SIM cards out of reach of small children.)
    1. Now insert the SIM card containing the contacts you want to import:
    2. Insert the SIM card into its slot with the gold contacts facing up and the cut corner facing out. t02005-1.jpg
    • When you release the SIM card make sure it is locked into position behind the catch so it doesn't spring out.
    • Replace the bumper and turn on your device.
    GrinningFool
  • www.repairmysidekick.org
  • May 09, 2008 | T-Mobile Sidekick II
    Apple MD440LL/A iPhone 4 8GB CDMA Verizon - White Logo
    144 people viewed this question
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
