Question about Ricoh Aficio 1022 All-In-One Laser Printer
I'm trying to copy an original 2 sided document. When I put the original in the document feeder it goes through but it doesn't turn the paper to get the other side and it doesn't print. It wants me to manually feed the other side. We purchased this used and I was told by the person who bought this that it does 2 to 2 sides. What am I doing wrong? I followed the steps in the manual and selected 2 sided for the original as well as for the copy. I'd appreciate any help. Thanks.
  • sukane May 20, 2009
    Thank you very much! It works like a charm now!
I suspect that the 'turn around gate" is not actuating. they mechanism can become dry and get stuck. Often a simple fix is to open the left cover of the feeder (feed in section), then lift up the top tray where you place the originals. You will see a black panel which is the "gate". Simply press on this and it will move down and the spring back up when released. That is often enough to free it up for the short-term; however you may need to do this after a period of non-use, as the solenoid that actuates it, bushings etc., are dry.
I hope this helps.
Please let me know, and rate solution
Posted on May 20, 2009
  • Anonymous May 20, 2009
    You're welcome. Glad I could help.
What sandmanmac said. the reason the gate got stuck on mine is because the little cushion pad actually got gummy and was holding the gate in place. I simply covered it with a piece of electrical tape. Problem solved.
Posted on Feb 16, 2010
Copying 8.5x8.5 original thru document feeder and it doesnt aal print
Most copier has an APS (Auto Paper Selection) as default, 8.5 x8.5 is a square original, I would suggest you manually select the paper tray (e.g. Letter) first (this will temporary disable the APS for this session), then lay it down on the original glass, or ADF (Auto Document Feeder).
If you do not disable APS, you will have paper jamming problem, you do not have 8.5 x8.5 is th paper tray, of course, you may try it feed from the by-pass tray, set the the paper size to 8.5 x8.5 or special size ....... Each manufacturer has a different name for the same function (terminology).
Nov 12, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
How do I scan a double sided copy on the Sharp 2300 N?
Put your paper in the document feeder. On the LCD screen touch the button that says 2 Sided. Then touch the one that says 2 to 2.
Aug 19, 2011 | Sharp MX-2300N Color Copier
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Screen says original loaded when nothing is in the adf
  1. Remove all the paper from the document feeder tray.
  2. Examine the condition of the paper, and then replace any ripped, dusty, curled, wrinkled, or bent paper.
  3. Make sure that the paper is a supported paper type for the product.
    NOTE: The ADF does not accept photo paper.
  4. Make sure that all the paper in the stack is the same size and type. Never load mixed types of paper in the document feeder tray. The product can only process one type of paper at a time.
  5. Tap the edges of a stack of 10 to 25 sheets of paper on a flat surface to make sure that the edges are even.
  6. Load the stack of paper print side up in the document feeder tray.
    NOTE: Do not load more than 25 pages in the document feeder tray. Larger stacks of paper can lead to pick problems. Figure 2: Reload the original document c02081020.gif Illustration of reloading the original document
  7. Press OK to continue the current task.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Dust or paper residue on the rollers or separator pad inside the ADF can cause paper feed issues.
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the product)
  2. Remove the stack of paper from the document feeder tray.
  3. Press the Power button (c01602202.gif ) to turn off the product.
  4. Disconnect the power cord from the rear of the product.
  5. Lift the cover of the ADF, and then find the rollers and the separator pad. Figure 4: Location of the ADF rollers and separator pad c00228595.gif 1 - ADF rollers 2 - Separator pad Illustration showing locations of the ADF rollers and separator pad
  6. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  7. Use the damp cloth to wipe any residue off of the rollers and the separator pad. Figure 5: ADF rollers c02081021.gif Photograph of ADF rollers Figure 6: ADF separator pad c02081022.gif Photograph of ADF separator pad
  8. Dry the rollers and separator pad with a dry, clean, lint-free cloth.
  9. Close the cover of the ADF.
  10. Reconnect the power cord to the rear of the product.
  11. Press the Power button (c01602202.gif ) to turn on the product.
  12. Reload the original document print side up in the document feeder tray.
  13. Try to perform the task again.
Perform a partial reset to restore the product settings to the default values.
  1. Write down any fax numbers and country/region and language settings stored in the product memory. CAUTION: A partial reset might remove all speed dials and other settings from the product memory.
  2. Disconnect the power cord from the rear of the product.
  3. Press and hold the # and 3 buttons at the same time while plugging the power cord into the rear of the product.
  4. Release the buttons after 30 seconds or when Part NVM Reset displays on the control panel.
  5. If the product does not turn on, press the Power button (c01602202.gif ) to turn it on.
  6. Press OK to continue the current task.
If you have completed all the steps listed above and are still experiencing a problem, service the product. If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I clean document feeder? It is putting
If it is just puting lines on the copies ONLY when using the feeder here is all you need to do to clean that thoroughly.
Get a phillips screw driver. Lift the document feeder, you will see the "seal glass" about 1 inch wide on the left side. Remove the 2 silver screws, One on each end. Lift that glass up and out. Lay it on a white piece of paper. Take some alcohol and a regular piece of copy paper and clean that until you see nothing on that glass by placing it against the white paper. Get every little speck off. Then put the glass back in.
If you want to clean the entire scanner that is a different procedure all together. Let me know .
Feb 10, 2010 | Xerox WorkCentre M20i All-In-One Laser...
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
Lines on my copies
As the page you wish to copy goes through the document feeder, it passes the scanner as well as a white plastic band that the scanner "compares" the dark writing or data on the page to. If this white plastic band is not very clean, the scanner reads the dirt as if it is part of the image you are scanning. Try cleaning the band as thoroughly as possible, as well as the small piece of glass to the left of the larger glass on the flat bed scanner. Make another copy to test your results.
Hope this helps!
May 07, 2009 | HP LaserJet M5025 MFP All-In-One Printer
Document Feeder won't work
hello! check and look to see if there is anything blocking the paper feed area, if all is good, get some denatured alcahol and clean the paper feed roller as it may have a build up of paper dust good luck brother sr tech
Jan 14, 2009 | Brother MFC-8460N All-In-One Printer
Keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Ricoh Aficio 1022 All-In-One Laser Printer Logo
166 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
