Question about Sanyo PLC-XU78 PLC-XU78 XGA 3000 LUMENS PROJECTOR Projector
Screen display has a pink tint - Sanyo PLC-XU78 PLC-XU78 XGA 3000 LUMENS PROJECTOR Projector
My Acer AL2416W is showing a tint of pink in all images I try to display, I have changed the cables with no change. I have taken the monitor to a new computer and it works fine ( no pink at all ). Why is...
The problem is in your old computer, the video graphics card is faulty, you mentioned the monitor was hooked up to the new computer and worked fine.
Apr 17, 2012 | Acer AL2416W Monitor
Lcd screen has pink tint
Hi Friend, In this case I would recommend you to please connect any external monitor to the laptop and check if the same issue happens on the external as well.
  • If the external one also has the same pink tint then try and update the video drivers for the system.
  • If the external display is fine without any tint, then, I believe the issue is with the LCD of the laptop itself, you can try restoring the screen to factory settings and check if it helps.
Otherwise, I would recommend you to please get in touch with the vendor itself.
Please let me know if it was of some help.
Thank you.
Jan 06, 2011 | Acer Aspire 5610-4648 Notebook
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Multimedia projector display too pink
check the vga cable, usualy its a broken wire inside
May 18, 2009 | HP VP6121 Multimedia Projector
Pink tint
your va and vs on power supply need to be adjusted but you have to know what your doing to set it right and requirs a volt meter
Jan 16, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Compaq laptop pink screen sometimes
The normal cause of a pink tinted screen is that the LCD back light is beginning to fail. Kind of like a regular florescent bulb does when it starts to go bad. It may last for a while, but eventually you'll have to replace it.
Ron
Dec 13, 2008 | Computers & Internet
Pink tint on Dell 1704FPT Flatpanel LCD
Unfortunately if you have tried a different machine (it could be a bad video card) and tried the cables most likely it is the screen itself. Typically when one of these lcd's begin to fail the pixles no longer access the blue field and you see mostly red instead of the other two colors. In short pink screen is terminal, it will last for a while longer.
Oct 01, 2008 | Computers & Internet
LP70+ projects a dark rose/pink tint upon the screen
The pink tint produced by my LP70+ projector was not a lamp issue but a connectivity issue. I swapped the old cable with a good known cable and the tint went away.
Aug 14, 2008 | InFocus LP70+ Multimedia Projector
Pink tint when shhoting in bright sunlight
Sane problem with C713, the view screen is dark and gives focus warning, then the pics come out with a pink tint. I believe it is the sensor or shutter problem. Can't get any solutions either.
Nov 12, 2007 | Kodak EasyShare CX7530 Digital Camera
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Sanyo PLC-XU78 PLC-XU78 XGA 3000 LUMENS PROJECTOR Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
