Question about Konica Minolta Copier Toner 7033/7040 900gm 950-414
The exit motor of my konica 7040 did not running, i clean it already.
  • Konica Minolta Master
  • 1,294 Answers
Verify the connectors and the fuser mechanical parts.
Posted on Jan 02, 2014
2 Suggested Answers
  • 6 Answers
SOURCE: konica 7040 error code F-34-3
Friend, this code refers to short-circuit the corona separation and transfer, check for accumulation of toner and do a cleanup in the corona.
Posted on Jun 01, 2010
How do i fix may konica 7033 displaying f52-1 error
F52-1 Cooling fan problem
or
F52 Main motor drive problem
Mar 27, 2015 | Konica Minolta Copier Toner 7033/7040...
Konica 7033 F-28-2
High Voltage issue have a tech come. Will have to have Old School knowledge you have a legacy Konica Machine.
Jun 12, 2014 | Konica Minolta Copier Toner 7033/7040...
Konica 7040 trouble code 35-1
Access the 25 mode (power the machine ON while holding down the 2 and 5 keys).
2. Select [1: Software switch setting].
3. Select software dipswitch #3 using the left up/down arrow.
4. Select bit number one.
5. Set the switch to 0 (OFF).
6. Press PREVIOUS SCREEN to end setting.
7. Power OFF/ON to exit the 25 mode.
Jun 09, 2014 | Konica Minolta Copier Toner 7033/7040...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
Error code c-3302
Fusing Cooling fan motor failure to turn, check fan motor 10 and fan motor 11 for proper connection which are located in the paper exit section of the machine, clean if clogged up with dust/dirt, check the fans move/ spin if they do not then replace the faulty fan motor
Aug 10, 2012 | Konica Minolta Bizhub c203 Copier
Konica 7040 error code F-34-3
May 21, 2010 | Konica Minolta Office Equipment & Supplies
Konica 7033 error code F-51-4
my machine incounter problem F 51 - 4 KONICA 7040 ,pls help to solve this problem.I already done checking the drum cart.
Sep 18, 2008 | Office Equipment & Supplies
Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Dec 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Copier Toner 7033/7040 900gm 950-414 Logo
37 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
