Question about Michley Lil Sew Mechanical Sewing Machine
Needle won't catch bottom bobbin thread
We were sewing fine and then had a thread tangle. I cannot seem to use the needle to catch the bottom bobbin thread. I've viewed the online instructions and tried everything I can find about it. No luck so far!
  • 1,271 Answers
Hi, you need to alter the timing, mostly related to the upstoke, as the needle returns, sadly i never worked on one of these however it sounds a classic timing issue...
Regards
Rob
www.electronicrepairs.co
Posted on Dec 30, 2013
What is happening when I sew and 3 threads come out of the bobbin? Or when it just freezes up and I can't get the needle to go up or down?
basically the problem comes from incorrect thread tensions
the main thread responsible is the needle thread as the tension is far too loose
tighten up that tension and it makes the needle on the up stroke pull the thread around the bobbin carrier and collects the bobbin thread and pulls it up to the material
with the needle thread too loose the needle thread is wrapped around the bobbin carrier again giving you the 3 threads ( 2 needle threads and 1 bobbin thread and the tangle jams the bobbin movement
Sep 29, 2016 | Sewing Machines
Won't catch bobbin thread
hi Shauna.
this is all i could find out from the internet.
Make sure the presser foot is up when seating the thread through the upper tension. Now, it's time to draw up your bobbin thread. Turn the hand wheel (TOWARDS YOU ONLY, never turn the hand wheel away from you) and hold the needle thread lightly. Tug on it as the needle goes down and then comes up again.
if this is off no help to you go to this link and see if its any good to you.
Frequently Asked Questions Singer Sewing
or this one.
Sewing Machines Won catch bobbin thread Google Search
Dec 13, 2017 | Sewing Machines
Singer 7430, Needle hits the bottom of the bobbin case.
when the needle breaks on a pin that can cause a
problem with the timing, the machine needs to be serviced
Dec 11, 2012 | Singer 7430 Sewing Machine
Bobbin thread keeps catching under the plate
Your needle may be new, but Is needle correct size for fabric you are sewing? If so, is needle all the way up as far as it will go in needle bar shaft, flat side in back & more rounded side facing you? Stretch knits and wovens, denims, and leather do not use same needle size. Jimmy
Apr 09, 2012 | Singer Quantum 9940 Computerized Sewing...
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
THE SEWING THREAD WILL NOT CATCH THE BOBBIN THREAD
the needle is not catching the thread on the down stroke have you got enough thread out on the bobing for the needle to catch
Jul 22, 2010 | Elna Heirloom Edition 6005
I can seem to get the bottom thread up
Try replacing the needle. sometimes a bent needle causes this.
It sounds like your timing may have been altered when your bobbin housing fell apart. This is difficult to repair without specialized tools and knowledge, so best get it to a repair shop.
If the machine is a common brand like Singer or Kenmore, go online and search for a manual. Many are available for under $10 or are free to download.
Nov 02, 2009 | Sewing Machines
Michley Lil Sew Mechanical Sewing Machine Logo
248 people viewed this question
Top Michley Sewing Machines Experts
erebooni
Level 1 Expert
Robin Hill
Robin Hill
Are you a Michley Sewing Machine Expert? Answer questions, earn points and help others
