Question about Kensington KeyFolio Bluetooth Keyboard and Case Stand, Replacement Keyboard for iPad - K39294US
Passcode needed for k39519us - Kensington KeyFolio Bluetooth Keyboard and Case Stand, Replacement Keyboard for iPad - K39294US
How can I delete my passcode altogether?
Go to Settings - Passcode and put it your passcode. An option then appears on the top of your screen to turn the passcode off.
Oct 18, 2015 | Apple Tablets & eReaders
How do you reset passcode on ipod touch?
You will need to know the present Passcode to access your iPod Touch and change the Passcode.
1. Go to Settings
2. Go to General
3. Go to Passcode Lock
4. Select "Change Passcode"
5. Remember your new Passcode.
Jun 15, 2014 | Apple iPod touch
I need to disable the pass code on my iPhone 4s
1. Open "Settings App" on your iPhone
2. Then select "General" from left panel
3. Select "Passcode Lock" on right side. Enter your current passcode to continue.
4. Now tap on "Turn Passcode Off". Enter your current passcode to continue. Now Passcode lock will be turned off.
May 30, 2014 | Cell Phones
My IPad has been hacked into I need to. Know how to change my password.
With the push of a button and pull of a slider, you can quickly access all of your iPad's contents, including any sensitive personal data that you've stored within it.
Such easy and unrestricted accessibility to your device could be dangerous in the hands of a stranger, which is why you enable a password to block its use by anyone but you.
If you believe that your password's confidentiality has been compromised, don't fret. You can change it using your iPad's Passcode Lock feature.
Tap "Settings" on the home screen.
Tap "General" on the left sidebar.
Tap "Passcode Lock" on the main pane to the right.
Type your current four-digit passcode in the "Enter Passcode" screen that appears.
Tap "Change Passcode." Type your current four-digit passcode again in the first "Change Passcode" screen that appears.
Enter a new four-digit passcode in the second "Change Passcode" screen.
Retype your new four-digit passcode in the third "Change Passcode" screen.
This will simultaneously verify and activate your new passcode.
http://support.apple.com/kb/HT4113
iOS: Using passcodes
http://support.apple.com/kb/ht1212
iOS: Forgotten passcode or device disabled after entering wrong passcode
Jan 13, 2014 | Computers & Internet
Acer Extensa 4630Z passcode for bluetooth
Passcode is the temporary code for wireless devices when pairing with each other to establish a secure connection. You can assign any numbers or codes you like for the connection to take place. Suppose when you are asked to enter the passcode, enter 123 on the computer's passcode box and then same 123 on the cellphone. It'll automatically accept, but you need to assign the passcode everytime you connect the devices (as I've mentioned for once connection only).
You can assign any numbers or letters as passcode, but it should be set the same code on both the devices.
Good luck.
Thanks for using FixYa.
Jul 12, 2010 | Acer Computers & Internet
Forgot my passcode
Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
Nov 10, 2009 | Apple iPhone 3G
Forgot passcode and i need to pair it with treo
The default passcode is 0000 or 00000 or 00000000
Aug 07, 2009 | Motorola Mobility H500 Headset
Kensington KeyFolio Bluetooth Keyboard and Case Stand, Replacement Keyboard for iPad - K39294US Logo
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
