Question about Ectaco EP586HT Dictionary/Translator
How to remove back cover to control if place for battery is not damaged? Translator does not work powered by battery
Translator does not work powered by battery. Only with ac/dc adapter
How to replace a cracked screen
Replacing a damaged laptop LCD screen can bring your laptop back to life.
You'll be able to access files you thought were lost and use the laptop just as you did before. And it's not as difficult as you might think.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
Hope this helps
http://www.laptopscreen.com/
watch video
Nov 06, 2012 | Computers & Internet
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
Lcd replace
You should the installation instructions with the new lcd screen
Hope this helps
watch video
Nov 04, 2012 | Computers & Internet
Advent t9307 power switch not working
Your laptop's power button sits directly on top of a device called a power button board. This is a small circuit board where all power and control buttons interface with your laptop's motherboard. The repetitive use of the power and control buttons can damage the power button board. Repairing your power button means removing and replacing the power button board, which requires partial disassembly of your laptop.
1.Power down your laptop. Unplug the AC power adapter and all external devices from the computer. Close the laptop's LCD panel and place the laptop face down. Rotate the laptop so the front opening edge is facing you. Remove the battery pack from its compartment on the laptop's bottom side.
2.Flip the laptop over, and pull open the display panel as far as possible. Use a thin, flat-head screwdriver to pry the keyboard cover from the laptop. The keyboard cover is the plastic piece situated above the keyboard assembly that houses the power button board.
3.Lift the keyboard cover out of the laptop slightly, and disconnect the cables extending from the power button board to the motherboard. Remove the keyboard cover from the laptop.
4.Place the keyboard cover face down on a flat surface. Remove the Phillips-head screws fastening the power button board to the cover, and remove it. If your speakers are situated inside the keyboard cover, disconnect the speaker cables from the power button board before removing it.
5.Place the new power button board inside the keyboard cover. Align the screw holes on the button board with the holes on the keyboard cover. Replace the Phillips-head screws fastening the button board to the keyboard cover. Reconnect the speaker cables to the button board, if necessary.
6.Reconnect the power button board's main cable to the motherboard. Place the keyboard cover back inside the slot above the keyboard assembly. Press down on the cover until it snaps into place. Replace the battery pack and reconnect all cables.
Sep 06, 2011 | Computers & Internet
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is...
First of all check your VGA cable is working or not.
If VGA cable is ok than do the following steps.
  1. Turn off all peripheral devices connected to the computer.
  2. Disconnect the computer's power cord from the AC power source (wall outlet or power adapter).
  3. Remove the computer cover.
  4. Locate the battery on the board (see figure below).
  5. With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the "+" and "-" on the battery.
  6. Wait for 1 to 5min then re-place the battery back again.
  7. Re-place the computer cover.
  8. Plug the computer and all devices back in.
Second step you can do is
1) Remove the RAM from the RAM bank clean it properly and insert it back again.
If still you are facing the same problem ... you can Remove the CPU fan and put some cooling paste on top of CPU and re-place the FAN back.
Jul 06, 2011 | LG Flatron L1710S 17" LCD Monitor
How do i replace the batteries in this device?
To install the batteries:1. With the back of the radio facing you, remove the belt clip (seediagram below) for easy access, then remove the Battery Coverby pressing down on the top center and sliding it down from theradio.2. Insert 4 AA batteries observing the polarity as shown. Installingthe batteries incorrectly will prevent the unit from operating ormay damage the unit.3. Return the Battery Cover by sliding it up on the radio. Replace thebelt clip, making sure it locks into place.
To install the batteries: 1. With the back of the radio facing you, remove the belt clip (see diagram below) for easy access, then remove the Battery Cover by pressing down on the top center and sliding it down from the radio. 2. Insert 4 AA batteries observing the polarity as shown. Installing the batteries incorrectly will prevent the unit from operating or may damage the unit. 3. Return the Battery Cover by sliding it up on the radio. Replace the belt clip, making sure it locks into place.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Midland LXT310 2-Way Radio
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    How to replace mirror in toyota corolla
    1) Disconnect the Corolla's negative cable to the battery.
    2) Remove the triangle-shaped interior mirror cover from the top of the
    door panel. Pry the cover off with your hands, a blunt plastic or
    wooden tool to prevent damage to your door trim.
    3) Take out the mirror wiring connection.
    4) Remove the door trim bracket around the mirror. Take out the
    mounting nuts.
    5) Pull the power mirror off the Toyota Corolla.
    1) Put the new mirror in place on the Camry.
    2) Re-install the mounting nuts making sure they are securley holding
    the mirror in place. Replace the mirror insulation.
    3) Reconnect the wiring to the new mirror.
    4) Install the triangle interior cover by snapping it back in place.
    5) Connect the negative battery cable.
    Thanks
    Xeeshan
    Nov 22, 2009 | 2005 Toyota Corolla
    I need to install a keyboard for a Dell Inspiron 1525. I need step by step directions
    Before you begin, Follow these steps carefully;
    1. Shut Down to turn off your computer. Ensure that the computer is off and not in a power management mode. If you cannot shut down the computer using the operating system, press and hold the power button for 4 seconds.
    2. Disconnect your computer and all attached devices from their electrical outlets. Disconnect any telephone or network cables from the computer
    3. Remove any installed cards from the ExpressCard slot.
    4. To help prevent damage to the system board, you must remove the battery from the battery bay before you service the computer. to do this, Turn the computer over, Slide the battery release latch until they click into place. Slide the battery out of the battery bay.
    5. Turn the computer top-side up, open the display, and press the power button to ground the system board. Now you are ready to remove your Keyboard;
    6. Removing the Center Control Cover, Remove the two screws securing the center control cover from the battery bay,
    7. Turn the computer top side up, and open the display as far as it will open.
    8. Insert a plastic scribe into the indent to lift the center control cover on the right side and ease the center control cover up.
    9. Disconnect the cable from the media control buttons connector located underneath the center control cover. NOTICE: To avoid damage to the data cable connected to the system board, ensure that you do not pull hard when you are raising the center control cover. NOTICE: To avoid damage to the center control cover, do not lift the cover on both sides simultaneously.
    10. Remove the center control cover.
    11. Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    12. Lift the keyboard and hold it up and slightly forward to access to the media control buttons connector.
    13. Disconnect the media control buttons connector and remove the media control buttons cable.
    14. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    15. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
    16. Slide the keyboard cable out of the keyboard connector.
    17. Replacing the Keyboard
      1. Slide the keyboard cable into the keyboard connector.
      2. Rotate the keyboard connector latch to secure the cable.
      3. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
      4. Press on the right edge near the top to snap the keyboard into place.
      5. Replace the two screws on the top of the keyboard.
    18. Replacing the Center Control Cover
      1. Reconnect the media control buttons cable to the connector below the keyboard.
      2. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
      3. Press on the right edge near the top to snap the keyboard into place.
      4. Replace the two screws on the top of the keyboard.
      5. Reconnect the media control buttons connector to the center control cover.
      6. Insert the left edge of the center control cover.
      7. Press from left to right until the cover snaps into place.
      8. In the battery bay, replace the two screws that secure the center control cover.
    Apr 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
    XM radio express blank screen
    I had the same problem with my Pioneer Inno Gex-Inno2BK XM radio receiver. One evening while leaving work, I gently took it out of the cradle & the screen suddenly went completely blank & all white. I could still hear music but there was no screen visible. Solution is this: (1) Gently remove the back cover which covers the battery. (2) Gently remove the dark blue square battery which is only about 1 inch (width) by 3/4 inch (height) by 1/4 of an inch in thickness. I removed mine by holding the receiver upside down & gently shaking the battery with one hand until the battery came out into my other hand. After about 4 or 5 gently shakes, it came out. (3) Wait about 15 seconds. (4) Place battery back into XM radio receiver being careful to line the copper power receptable on the battery with a corresponding surface inside the receiver. Each copper area is only about 1/10 of an inch by 1/10 of an inch. Use this as a guide when putting the battery back in to make sure it's lined up properly. (5) Gently slide the cover back in place & let it snap into place. (6) Turn receiver back on by pushing power button like normal. (7) XM receiver should boot up with a full display just like new. All recorded songs are still in place. Nothing has been lost. Problem solved. Root cause of problem is probably some type of boot-up issue with the receiver in which the battery (i.e., the power supply) just happened to be slightly ajar...which also persisted even when placing the receiver back in the cradle until the above steps were taken. The steps above worked beautifully for me...Hope it works for you as well! Have A Great Day...Tom Armstrong
    Dec 15, 2008 | Pioneer GEX-INNO1 XM Radio Receiver with...
    Ectaco EP586HT Dictionary/Translator Logo
    32 people viewed this question
    Top Ectaco Office Equipment & Supplies Experts
    Piyal Perera
    Piyal Perera
    tony wahlman
    tony wahlman
    Are you an Ectaco Office Equipment and Supply Expert? Answer questions, earn points and help others
