Question about Bennoti Espresso/Cappuccino Maker
Water does not flowBennoti coffee maker does not work
Motor runs but water does not flow through the unit
No water flow
The hot water works, but when I run coffee, the water only goes into the used BIN, NOT the spouts. I can't get the water to go through to brew the coffee..
HELP
Feb 04, 2014 | Krups Orchestro 889 Espresso Machine
Coffee maker does not heat water. Power is on, but motor appears not to be running
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101=-
May 04, 2011 | Keurig Elite B40 Coffee Maker
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
Fault F 17 appears when in use. Starts grinding the beans but no coffee in the cup yet. What does F17 mean?
f 17 is no water flow. It usually occurs when the brew unit has not been cleaned regularly, when the coffee grind size is set too fine, or when oily beans are used. You can try to soak the brew unit in hot water for a while, and run water through it in the sink. Unfortunately, most cases require brew unit replacement. A properly cleaned and maintained brew unit should last the life of the machine.
Jan 26, 2011 | Miele CVA4070 Coffee Maker
Water will get hot but not flow to the mixing basket
Most likely your system needs to be de-limed. All water has a certain amount of dissolved minerals in it and when heated those minerals will precipitate out into a white, crusty material. Often this material will clog up the works of your coffee maker.
In order to remove the deposits, you have to increase the acidity of the liquid within the coffee maker. The easiest way to do this is to drain the water and then fill the maker with about 18 ounces of white vinegar that you can buy from your local supermarket.
It may take some time before the lime deposits dissolve and you may even have to use a wire probe to carefully remove any blockage of any of the holes that the water has to flow-through to get through the system.
After you've got the lime removed and the unit is working properly, run some clean water through the system and clean any external parts to make sure you don't get vinegar flavored coffee.
Dec 22, 2010 | Bunn VPR Coffee Maker
Water for steamer but no water flows to make coffee
Remove the screw and shower screen under the brew head, make sure screen is clean, try running the head to see if water flows, if no water remove allen wrench screws, and check spring and valve seat, DO NOT LOSE SPRING AND VALVE. Try running head, if water does not flow, reassemble and descale machine.
Sep 10, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Water flow has slowed down.
remove the spray head and clean it .also run the cleaning spring through the spray head tube this is what makes them slow down is minerals in the water.
Jul 02, 2009 | Bunn NHB Coffee Maker
Grinding coffee but water not making coffee
Check to make sure the quantity button has not been reprogrammed. To do so, push and hold the coffee button until coffee flows through. Also be sure to check the brew-unit. In some cases if the b-unit is plugged, it will not allow water to flow through. Also check to be sure you are not grinding too fine, if coffee is too fine it too will plug the chamber...........Hope it helps.
Steven,
info@northwestkitchenware.com
Jun 30, 2009 | Saeco Royal Digital Plus Coffee...
I have a Gaggia Evolution expresso maker about 8 years old. When button is pressed to start motor it just hums and no hot water comes out. The motor only runs if I open the steam outlet
Try this, under the grouphead, there is a screw and screen, remove those, and check screen to see if it is clogged, when screen is removed press button to brew, if water flows freely then problem is at the screen, if no water flows, then it is on the inside of the machine. You will have to run a descale cycle to clear out machine. Check the folling pic for the screen location.2722dbe.jpg
Jun 27, 2009 | Gaggia Syncrony Compact Coffee...
Bennoti Espresso/Cappuccino Maker Logo
Top Bennoti Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Bennoti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
