Question about Pyle Pro - PTCDS1U - Home Ptcds1u Classical Turntable With
My PTCDS1U just started playing too slowly despite my attempts to adjust the speed
The plate the record sits on seems to be wobbly & my records are playing to slowly. I adjusted the speed from 33 to 45 but that causes them to play way too fast. This record player has worked great for the last year. I even adjusted the transit screw with no luck.
    Scholar:
  • 155 Answers
Is this a belt drive turntable? If so, replace the belt - its slipping.
Posted on Dec 30, 2013
I recorded an event but when I recorded an event but when I replay it the little cassette jumps or skips. What is causing this to happen?
standard play" (SP) quality. Other speeds include "long play" (LP), and "extended play" (EP) or "super long play" (SLP)
https://en.wikipedia.org/wiki/VHS
mismatch of recorded vhs speed to play back speed could be cause
Oct 06, 2015 | Video Cameras
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
Troy built storm 2890 snowblower slow in reverse
There is an inspection pan on bottom of snow blower remove the 2 or 4 bolts and drop pan
inside you will see an aluminum wheel (drive wheel) also a rubber faced wheel whitch runs on the aluminum wheel at a right angle (like a needle runs on a record on a record player.
Clean plate and rubber wheel using brake clean to degrease surface .
Also there is an adjustment to move the rubber wheel farther to the left for more reverse speed but in doing that you might lose top speed forward.
Mar 02, 2015 | Garden
Jvc service center
If it does this when playing a 12 inch record then it could be that the device has been set to play a 7 inch record. The skating across is either a worn stylus, wrong skate setting (if it has one) or not enough stylus pressure. To correct the pressure one. Make tiny adjustments to the weight on the end of the arm. Each time you need to test by playing a record. If it sits in the groove and doesn't skate, plus doesn't make a rumble sound, you have the pressure right. Too much pressure causes it to rumble, too little and it will leave the groove. If the weight is numbered try it at 3, then take it up to 4 + in small steps, testing it each time you move up. It's a case of trial and error to get it right.
Dec 29, 2017 | Audio Players & Recorders
Playing records too slowly
It's likely that the belt has moved off where it should be. If the stylus was damage it would slide across the record or cause poor sound. It would not affect the speed unless there was too much pressure on the stylus, but you would feel that as the head of the arm would feel heavy.
May 24, 2013 | Crosley Conductor CR73 Turntable
Record skipping despite new needle
It could be something to do with the turnatable's platter. Is the matt that the record sits on faulty. Does the platter wobble up and down with no record on it? If you can see this happening you might need to check the platter out. If it's a belt driven the belt can come out of position causing such problems. Also objects can get stuck inside the platter. Especially if you have small children in the house!!!
Feb 28, 2013 | Crosley Cr704 Audio Shelf System
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Pyle Pro - PTCDS1U - Home Ptcds1u Classical Turntable With Logo
128 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
