Question about Samsung Galaxy Computers & Internet
Power not on sumsung lcd monitor - Galaxy Samsung Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 2,226 Answers
Check video card
Posted on May 11, 2014
I have LN32D403 32-Inch 720p 60Hz LCD HDTV sumsung tv but it can not read my Toshiba hard drive i want to know what type of hard drive i can use in it thank u
Hi there, unfortunately there can be a problem with power insufficiency... if you have two USB connectors side by side on the back of TV set , please use Y Usb cabel and connect both in TV set and the other end to HDD. Or if your HDD comes with external power supply ac adapter connect it first. Then try again.Tnx
Sep 17, 2013 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
Sumsung lcd monitor smps top 247f bund , fuse opend
  • that is a problem of smps
  • check the fuse inside the smps
  • check the component which blows the fuse e.g.diodes transistor
  • if faulty replace it
Dec 05, 2012 | Computers & Internet
Power cable for sumsung syncmaster 960bf dc14v
http://www.ebay.co.uk/itm/14V-AC-power-adapter-Samsung-syncmaster-960BF-19in-LCD-CORD-supply-charger-DC-NE-/250897192700?pt=LH_DefaultDomain_0&hash=item3a6aa356fc
Or open it and replace the end capacitors.
Apr 07, 2012 | Samsung Computers & Internet
Good day, my sumsung syncmaster 540n monitor did not show the display however it starts after 40 to one hour .What is the problem.
Hello, The problem might be that the signal cable at the back was not properly inserted, i mean the cable with the blue color and has 15 pins. Make sure it is properly inserted to your monitor as well as the other end to your Desktop. If this continues,Bring another LCD monitor, a good one and connect it to your system, to see what happens. If it works fine then the former monitor is faulty, if not your system has the problem. Regards
Nov 26, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Power suply led lamp dosent snine, the screen is blank all time?!
yes it always happen to sumsung LCD, but don't you worry, just follow my tips to repair your LCD MOnitor. Click here for the tips.
Aug 09, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
The lcd turned black, even though the power button is on
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
Jun 23, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
My sumsung tft is no display
I will assume that you already try thus monitor with other PC with the same result.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Samsung SyncMaster 17" TFT LCD Monitor
We dont have drivers of sumsung syncmaster 920n
LCD usually doesnt require a driver, it is plug and play
Jul 14, 2009 | Samsung SyncMaster 920N 19" LCD Monitor
Loose LCD Monitor
Sumsung technical support team may help
Jun 17, 2007 | Samsung X05 Notebook
Computers & Internet Logo
24 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
