Question about Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers
Cisco user name and password - Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 265 Answers
Either admin/admin or admin/password are the defaults.
Posted on Dec 30, 2013
3 Suggested Answers
melvinlpeter
  • 30 Answers
SOURCE: Hi i have 1841 router what is the default user
  • Follow these steps in order to recover your password:
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
      Use these terminal settings:
      • 9600 baud rate
      • No parity
      • 8 data bits
      • 1 stop bit
      • No flow control
    2. If you can access the router, type show version at the prompt, and record the configuration register setting.
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    3. Use the power switch in order to turn off the router, and then turn the router back on.
      Important Notes:
      • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
      • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    6. Type reset at the rommon 2> prompt.
      The router reboots, but ignores the saved configuration.
    7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
    8. Type enable at the Router> prompt.
      You are in enable mode and should see the Router# prompt.
    9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
      Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
    10. Type show running-config.
      The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
    11. Type configure terminal.
      The hostname(config)# prompt appears.
    12. Type enable secret password> in order to change the enable secret password. For example:
      hostname(config)#enable secret cisco
    13. Issue the no shutdown command on every interface that you use.
      If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
      Router#show ip interface brief
    14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
      hostname(config)#config-register 0x2102
    15. Press Ctrl-z or end in order to leave the configuration mode.
      The hostname# prompt appears.
    16. Type write memory or copy running-config startup-config in order to commit the changes.
Posted on Mar 01, 2011
SOURCE: -where can i find my cisco password? -what is my
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 02, 2011
Wha is cisco guest password
user name cisco
password cisco
Feb 13, 2016 | Cisco Computers & Internet
Tip
Changing Channels on your Routers
You may try to use different channels on the router to get a better signal. Follow the steps below how to change channels on your router:
1. Connect your computer to the router via an Ethernet cable and open your web browser (normally Internet Explorer, which can be found on your desktop or on the Start Menu in Windows XP).
2. Once your browser opens, input http://192.168.1.1 into the "Address bar".
3. You'll be prompted for a User Name and Password. Leave the User Name blank and type in admin as the password.
Cisco Interface (if the setup page has a Cisco Logo)
Go to Wireless Tab
SSID: (e.g. Vic or your name or last name)
Channel: Any from 1-11
Then hit Save Settings.
Regular Linksys Interface (if the setup page has no Cisco Logo)
Under Setup:
Then hit Apply
After doing this you should have a better Wireless signal from your router....
on Jan 08, 2010 | Linksys Wireless-G WRT54G Router
Tip
Changing Channels on your Routers.
Go to Wireless Tab
Under Setup:
Then hit Apply
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
How to a change password wifi cisco dpc2320
plug ethernet cable directly between a pc and router and then type in dos prompt ipconfig to find ip address of default gateway if this is the only router. Then note ip addressd it will be most likely 192.168.0.1 or 10.0.0.1 and put this into an internet brower url address box and you should be able to log into the router unless it has a password and user name set . Go may need to google the default user name and password for the router . go into wireless security settings and then you should be able to change the encryption key.
Oct 28, 2014 | Cisco Model DPC2320 DOCSIS 2.0 Wireless...
How to enable wireless on compaq laptop
password for wireless is not the same as your windows password. log-in credentials are usually found on the router. try looking at the bottom to find default user name and password
Nov 25, 2017 | HP Compaq 6910p (GU888US) PC Notebook
Tip
How to change Wireless Channel on LInksys Routers...
Try to use different channels on a wireless router to get a better signal. Follow the steps below how to change channels on your router:
1.Connect your computer to the router via an Ethernet cable and open your web browser (normally Internet Explorer, which can be found on your desktop or on the Start Menu in Windows XP).
2.Once your browser opens, input http://192.168.1.1 into the "Address bar".
3.You'll be prompted for a User Name and Password. Leave the User Name blank and type in admin as the password.
Go to Wireless Tab
SSID:(e.g. Vic or your name or last name)
Channel:Any from 1-11
Under Setup:
Then hit Apply
Hope this help everyone.
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about Linksys E1000 cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
What is the default enable Password for cisco 7604 - sup720-3b
The default user name and password for Cisco routers and switches is usually:
user name: Cisco password: Cisco
Make sure to capitalize the C's.
Mar 16, 2011 | Cisco 7604 Chas 4-slot 2 SUP720-3B 2 PS
Open a form using a password and user name
dis is the logon page in html.....................
<html>
<title>
login page
</title>
<head>
<br>
<br>
<center><b> Interactive Voice Responce System</center></b>
</head>
<body bgcolor="light gray" text=663250 font=bolditalic>
<br>
<br>
User name:<input type=text name = user>
<BR><BR>
Password : <input tye="password" name=pwd>
<BR><BR>
<CENTER> <input type=submit value = login name= login> </CENTER>
</body>
</html>
Jan 22, 2009 | Cisco IPCX OR IP IVR 3.5 3.Y MS SQL SVR 1...
Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers Logo
53 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
