Question about Pitney Bowes Office Equipment & Supplies
Imagistics sx2100 noise when printing
The fax machine has started to make a loud thumping noise when it prints. There is also a strong toner-like smell from the machine. Printing quality is good.
checkitright
  • 1362 Answers
SOURCE: lines printing out on faxes
white or black lines? what kind of machine? does it have lines when sending?
Posted on Dec 12, 2007
  • 1003 Answers
SOURCE: installed a brand new cartridge in hp 1040 fax but prints very poorly(light )
remove the new cartridge
TAKE A MICROFIBER CLOTH MOISTENED WITH RUBBING ALCOHOL AND WIPE THE PRINT HEAD ( THE PART OF THE CARTRIDGE THAT CONTACTS PAPER)
REINSTALL THE CARTRIDGE THEN TEST
ALSO YOU MAY WANT TO WIPE OFF THE CONTACTS ON THE BACK OF THE INK CARTRIDE WITH THE MICROFIBER CLOTH MAKING SURE THERE ARE NO FINGERPRINTS ON THE CONTACTS
Posted on Jan 18, 2008
  • 42 Answers
SOURCE: poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Posted on Mar 17, 2008
SOURCE: imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Posted on Aug 06, 2008
playedaround
SOURCE: PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Posted on May 27, 2009
Splotches in prints from our SX 1480
This is actually a Muratec machine. This is not an uncommon fault and it is ALWAYS a faulty toner cartridge. Although you say you have changed it, I doubt you have replaced it with a new one.
Change it I can guarantee it will cure it. I know as I am a muratec engineer!
Jan 27, 2014 | Pitney Bowes Compatible Imagistics / OCE...
I have a Minolta Di181 black and white copier. It started printing lines all through the paper and was a little dark. I bought another copy machine because this one is old. It is a imagistics zc25 this...
Well, you put your self into a pickel. With the Di181 you most likly neede a new drum and cln blade & a good cleaning. Now with the Imagistics, you may have the same problem, but you put Minolta toner into a Imagistics. Thats like putting oil into water and wonder why they don't mix? Now you need to replace the drum & blade & developer & toner and vaccum out all the toner and start off with all new. Good Luck
Jul 28, 2010 | Panasonic DP-8020E Black and White Copier
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Noise(grinding), can't print, can't receive fax, multiple prints
is there a error message in the display, ley me kno what it is and i will try and help - brother tech
Nov 20, 2008 | Brother MFC-8440 All-In-One Laser Printer
Noisy operation and black marks on left side of printed paper
vacuum out the waste toner passages that lead from the drum and transfer belt to the waste toner container. Toner is building up inside the transfer belt and/or drum and has no place to go except onto your paper.
Nov 06, 2008 | Samsung CLP-510 Laser Printer
Imagistics 2500
With that model I believe you have to leave the toner door open and press start
Oct 24, 2008 | Brother MFC-8220 Fax
Strong noise
sounds like the fuser gear is broken.
Jun 06, 2008 | Brother MFC-8220 Fax
Very poor print quality
the loud you hear indicate improper of mechanism of fax get drum unit out  and check for good condition of the unit (no broken in drum gear-or bad cleaning blade)-and reinstall it again- rip over toner box many times and check it  in horizontal level many times.if all above  does not work -you will have a problem in drum unit or your fax mechanism(broken gears-chain or belt defective-bad selonid-clutch-
Mar 12, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
27 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
