Question about Mackie 1202vlz3 12 Channel Mixer
Mackie mixer overheats
Mixer after being on for maybe 30 minutes starts heating up...then after another maybe 30 minutes starts breaking up like it has a bad speaker wire connection...I check all connections but still does it. I was told it just needed cleaning..any suggestions?
Cleaning may be an issue, maybe try putting something under it to air can get to the bottom. I've had to do that with my mixer.
Posted on Dec 31, 2013
SOURCE: hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
Posted on May 26, 2009
young red
  • 3 Answers
SOURCE: bad transormer in my Mackie 1202 20 watt mixer
how u hook up a mixer
Posted on Jul 31, 2009
  • 4234 Answers
SOURCE: wirings connections from mixer to equalizer to
The connections can be accomplished in 2 ways: Direct or using insert cables. The most common way is directly as follows:
Mixer L/R ===> EQ Input L/R ==> Amp Input L/R ==> Speakers L/R
Using insert cables you would have a single 1/4" connector at the mixer end (inserted in to the "insert" L or R) and the other end into the EQ. If you need more details about this method, please post the model of the EQ so I can determine the type of insert cable required.
Hope this helps.
Dan
Posted on Mar 15, 2010
  • 5603 Answers
SOURCE: No sound
Your power amp should be connected to MAIN OUT left and right. NOT the MAIN "in".
The CD is connected correctely as you described. Make sure the CD has a line level output to match the input expected by the mixer.
Note:Walkman style CD players require a special cable to go between 1/8 inch stereo to dual RCA plugs.
You have to advance the MAIN fader.
You should be using TRS interconnect cables from the mixer to your amps OR using XLR cables.
Posted on Jul 24, 2010
sparky1500
  • 1066 Answers
SOURCE: How can I connect my mackie mixer 1202-vlz3 to my
use the xlr (3 prong) main left and right outputs of the board. get xlr to 1/4 inch cables. one end will be 3 prong, to plug into the mixer, then the other end will be a mono 1/4 inch plug, like a big headphone plug. Then you have to get a dual mono 1/4 inch to stereo 1/8 inch adapter and plug it noto the line in. if there is no lone in, but a microphone jack instead, you will get a mono signal instead of a stereo signal. in this case, just use 1 channel of the mixer, instead of both of the stereo outs, and use a single mono 1/4 inch to mono 1/8 inch adapter.
the xlr to 1/4 inch cables can be purchased at a music store. the 1/4 inch to 1/8 inch adapters will probably need to be purchased at radio shack.
Posted on Nov 30, 2010
Mackie 402 turning itself off help please!
You should return it, that's what the warranty is for. Don't even think about trying to sort it yourself
Nov 25, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
How do i setup my mackie 1202
Please view videos on YouTube. Search for "mixer setup". There are a bunch, and the information and techniqes are the same for almost any of the analog mixers. You might refine the search to Mackie mixers.
Mar 17, 2011 | Mackie Music
My laptop is feeding through my Xenyx 1622fx mixer and output to my Mackie SRM450's. Getting the 'hum' which is a fuzzy noise. Is this solved with ground loop box?
Try hooking your mixer up to your Mackies without the laptop. Does the hum go away? Try hooking your laptop output up to the Mackies without the mixer. Does the hum go away? Make sure that all your power cables run from the same outlet and have the ground or third pin intact on the plug. Also make sure that you are using shielded cables for any connection that carries an audio signal. This includes the cables going to your Mackies as they are powered amplified monitors. Make sure that the cables to your Mackies are balanced and haven't been altered to unbalanced. You will need to use unbalanced cables from your laptop unfortunately but try to find ones with a shield and three conductors ( right and left signals and a common or ground) that have a separate shield from the common. The shield should only be connected to common at the output of the device where the signal starts. A better explanation is at these links:http://www.epanorama.net/documents/groundloop/ also http://www.epanorama.net/documents/groundloop/cable_shielding.html
Oct 17, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I wood like purchase macki mixer consoles
Here is a link to buy online or find a dealer:http://www.mackie.com/products/1642vlz3/ I would also recommend this store:http://www.sweetwater.com/ Enjoy your purchase.
Mar 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 16 Channel....when I power up it is blowing fuses...
check ur power supply unit inside...there maybe component already shorted or short circuit...whether a transistor...
Jan 03, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1202vlz3 12 Channel Mixer Logo
48 people viewed this question
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
