Question about Refrigerators
Frigidaire FRS26R4CB1 In the last week, all the liquids have started freezing up in the fridge side. Temperature has always been set at default and the setting was unchanged when it first froze up. I have dropped the setting to the warmest setting and fridge is still averaging 18 degrees. I disassembled the entire control box to check if damper had ice making it stick open or if it was inoperable. Everything looked normal and I can hear damper door opening and closing when running. It sounds like the temperature control box is not operating properly. How can I test that is the actually problem without replaing the part? Or is there another part that I should look at first?Freezer is still operating properly. Thanks for any insight you may have.
    Problem Solver:
  • 8 Answers
It sounds like you have it pinpointed with the control being the problem. There is an adjustment, but it's complicated, and there's different types. A refrigerator is like politics..you have an obvious annoyance, there, but often the core cause is less obvious. Ambient room temperatures in winter dropping lower tend to trick a fridge into thinking it's time to shut off inappropriately..the control sensor in the milk-side says it's safe; while in the freezer, your ice cream is doomed..sort of like the congress and senate, if you know what I'm saying. Your problem, however, is the opposite, as your 'ice-box' doesn't stop running at all (right? yes, in fact you better go catch it before it runs away, ha-ha!)..well. Something simple that can cause your problem is plugged condenser coils which are next to the compressor. You can see them by removing the cardboard cover in back. ALWAYS REPLACE THE COVER. The coils are either a box-type or they spread all around underneath. If they are full of dust and pet hair, and chewing-gum foil wrappers, etc., get a long wire bristle brush and poke it around to free the coils of all that air-flow restriction, and that will make a big difference..Also, voting out all the incumbents. Happy New Year. And G-d bless America
Posted on Dec 30, 2013
  • Elton B
    Elton B Jan 05, 2014
    Have replaced both the fridge temp control box and the damper. Still have same issues. If I run fridge on default setting, it will get down to about 18 degrees. I found I can switch fridge off and just run freezer on 2 (default is about 3.5), and keep fridge around 30. When I turn fridge off, I can hear the damper closing but I am still feeling cold air come thru. Leads me to believe damper is bad. I guess I could have gotten a bad part.Any ideas on what else problem could bee
  • CongressmanT Jan 05, 2014
    Unless your coils are plugged, it can only be the control. Different control designs work differently. Important where you place the sensor bulb. I fixed an under-counter fridge with an old,OLD MADE IN USA control that had actual brass on it. It didn't fit in the application so I just left it hanging out in space there inside the box. After throwing away the asian control it came with, it works fine.
HVACRH20
  • 237 Answers
SOURCE: Hot point side by side electronics not operating damper
See if you have some paperwork on how to test, etc. located in a plastic bag taped up to the underside of the fridge. Pull the front vent cover off and you should see (feel) a bag taped up there with the test paperwork in it. If you don't have it let us know and maybe I can email it to you.
Posted on Dec 26, 2006
  • 1314 Answers
SOURCE: Temperature variation in freezer on Whirlpool ED22TQFXN
need your model number for unit reply but dont rare me till we are done get model num off serial plate in fridge
Posted on Jan 02, 2008
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
SOURCE: Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Posted on Aug 18, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
Refrigerator side freezing and cannot control temp.
099b99d4-9ea3-4dba-a2ca-6c92989fe8af.jpgLook and see if the air damper called a=> 5304482075 Temperature Control Thermostat is opening and closing after selecting a different temperature. This along with the termostat are what controls the fresh food section temperatures. I am here should you have questions, Thanks Sea Breeze
Apr 25, 2013 | Frigidaire Refrigerators
My freezer side isn't freezing. fridge side seems to be working
If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
Apr 03, 2010 | Amana SXD524VW Side by Side Refrigerator
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Leak under frigerator
leaking inside of fridge? your defrost drain is plugged and running from freezer into fridge around once a day....
May 24, 2009 | Frigidaire FRS26R4A Side by Side...
FRE196AS frigidaire fridge/freezer - fridge freezes everything!
Hello Nicola,
I suggest you contact Frigidaire in the UK, and explain the problem to them. I have included their website for you to do so. You can even call them. I checked with Frigidaire in the US and Customer Service tells me your fridge should not be failing at this point. Contact Customer Service and tell them how disappointed you are in the product; explain the issue; and insist they offer assistance to repair it. Frigidaire Customer Service here does not want to lose any customers, and that includes you. Be nice, but firm with them. I hope this helps you in some way. Let me know if I can further assist. Just trying to to help. :)
http://www.frigidaire.co.uk/contact.asp
Feb 17, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Oct 14, 2007 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
