Printer not clearly printed - Office Equipment & Supplies
How do I stop my printer from printing memory clear report? so it can print.
Sign-in into printer (check the OM) and push "Stop Printing" or "Clean Printing queue" - depending on model.
Feb 19, 2015 | Canon Pixma Mx432 - Multifunction Fax /...
Why my Fargo ProL Printer is not printing my Card Back Clear?
Hi, Its not clear what you are saying.
First, what kind of ribbon are you using for printing, and what kind of lamination ribbon are you using?
what are you trying to print on the front and back?
Feb 17, 2015 | Fargo Pro L ID Thermal Printer
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows)
a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
Dec 28, 2013 | HP LaserJet 5200 Printer
The printer prints one page clearly. Given 3
Try to reset your printer to factiry default from it's main menu. and check and you can try uninstalling and reinstallling your printer as well/
Jul 27, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a problem with t644 indicated 900.00 service rip software before this error printer indicated 960 service.after turn printer off then on error code indicated immediatly
Try this...power off printer. Then if it is a network printer go the to print server and clear all the documents from the print cue. If it is a local printer clear all documents in the local print cue then power the printer back on. Once the printer powers up the error should clear, if it doesn't clear power the unit back off and ensure that all documents have been removed from the print cue then power printer back on. This worked for me on the C782e, x854e and x940e models that I have.
Jul 04, 2009 | Lexmark T644 Laser Printer
I have Dell 1600n and run Windows Vista 32-bit. Whenever I print, I have to manually clear the print que. How do I have the print que automatically cleared after every print?
Go to the printer properties and untick print que and select print directly t o printer option.Alternatively download the rpcs drivers instead.
Jun 25, 2009 | Dell 1600n All-In-One Laser Printer
Won"t print, was using printer before
Yes, you may need to clear the print queue by restarting it and then try printing again. Its like rebooting your computer. Go to control panel>administrative tools>then Services. In Services, you'll see a list of programs, scroll down to Print Spooler then right click on it and choose restart or stop then restart. This will clear your print queue. Then try printing again. If that did not clear it and allow you to print, then let me know and we'll try another way. Pls rate this solution.
May 07, 2009 | HP Photosmart C5280 Printer
PRINTER PROBLEM where is my hp tool box? I HAVE INSTALLED NEW INK CARTRIDGES AND NOW MY PRINTER PRINTS OUT A LOAD OF PRINT I CANT UNDERSTAND. THANKYOU
Try double-clicking on the printer in the Printers and Faxes folder and clear any pending jobs. Turn off and disconnect the power cable from the printer for a few minutes to clear its buffer. Keep the paper removed from the tray during this process and only re-insert it after the printer has stopped attempting to print. When the spooler and buffer are cleared normal printing should resume.
Nov 11, 2008 | HP Deskjet 6940 InkJet Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
11 people viewed this question
jasbo
jasbo
